Kubota D1105 - EF07 Engine Rolling Coal at Altitude
   / Kubota D1105 - EF07 Engine Rolling Coal at Altitude #11
A 3 percent loss of power per 1000 ft means at 10k it is down 30 percent. It probably even feels like it is worse than that too. You need some boost.
   / Kubota D1105 - EF07 Engine Rolling Coal at Altitude #12
Either some boost or some more cubic inches. For example if the implements you intend to run require 25pto horsepower you would need a 35PTO hp tractor at high altitude just to be net you the 25 you need to run the implement. Even then it would be advisable to have it tuned to run properly in thin air.
2007 Kenworth (A55788)
2017 Ford Transit 350 Handicapped Van (A55788)
2017 Ford Transit...
2008 Dodge Avenger Sedan (A55758)
2008 Dodge Avenger...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
2012 Ford F-550 Crew Cab Truck (A55852)
2012 Ford F-550...
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
