Kubota BX25D Help
/ Kubota BX25D Help #1
B
bob bulson
Guest
2013 kubota bx25d with 50 hrs. has loss of power . idles fine as soon as a load is put on it it want's to quite. thought it had water in fuel so changed all filters added additive and fresh fuel problem has only gotten worse. when idleing and you give it throttle it surges up and down. any ideas?
/ Kubota BX25D Help #3
Assuming you checked the air cleaner also.....maybe.... check for a governor malfunction, injection pressure, injection nozzle clogged, injection pump malfunction. I reference the kubota trouble shooting guide in the WSM.
/ Kubota BX25D Help #4
Where are you getting/keeping your fuel?
Is your lift pump operating?
You thought you had fuel issues, why? Did you drain the tractors fuel tank before refilling? What additive did you add?
Double check your air filter / air intake.
/ Kubota BX25D Help #5
May want to test for gasoline in the fuel.
/ Kubota BX25D Help #6
Sure sounds like a fuel issue. If you already changed the filters and fuel, I'd suspect you have a blockage at the fuel pickup point in the tank. May have to drain it and try cleaning it out with a shop vac.
/ Kubota BX25D Help #7
Thinking along the same lines!
/ Kubota BX25D Help #8
Had a similar problem with by bx23--finally figured out that the seat wasnt locked in the correct position which caused a similar problem--sounds simplistic but make sure its not that. The test for this is that it revs fine but dies when you try to use the forward/ reverse pedal.
/ Kubota BX25D Help #10
Weird. The OP made his first post asking for help, hasn't come back apparently, and now his name is not "clickable". Did he de-register or something? I've noted this before, but when Briana moves posts, particularly initial posts, it seems a majority of the time the OP never posts back. I have to assume they can't find their initial post and assume it was deleted. Also, unlike most other forums, TBN does not leave a link to the original post with an annotation that it was "Moved". Most other sites leave that link so you can click it and bring up the new thread in the new forum. Why not here?? I have to think TBN looses a lot of new members as a result of how they administer "moved" posts.
2001 Club Car Carryall 6 Medical Utility Cart (A64553)
2001 Club Car...
Westendorf Loader Bucket (A66408)
Westendorf Loader...
2020 FORD F-350 (A65643)
2020 FORD F-350...
1999 Sterling Dump Truck (A66285)
1999 Sterling Dump...
2013 PETERBILT 367 MIDROOF SLEEPER (INOPERABLE) (A65643)
2013 PETERBILT 367...
2001 Freightliner FL70 Day Cab Truck, VIN # 1FUBBUAK21HJ24793 (A65563)
2001 Freightliner...
