kubota B8200 Hydraulics problem
/ kubota B8200 Hydraulics problem #1
AndyF
Central NY
Kubota B8200 & B7200
What's the best way to troubleshoot this problem?
Both the 3 point and FEL on my B8200 have started to operate very jerkily, slowly and with little power. I checked the dipstick and the fluid level is OK and the fluid looks fine. I also hear some pulsing in the hydraulics when I try to use the 3 point or FEL. The problem started about a week ago without warning after the tractor had been idle for several weeks.
/ kubota B8200 Hydraulics problem #2
Andy,
I am not really familiar with your model of tractor, but the usual procedure is to check/change/clean any fliters or screens in the hydraulic system. Sounds like the pump could be starving for fluid because of a plugged filter or suction screen.
It could also be sucking air in somewhere around a loose fitting or something on the suction side of the pump.
Ben
Genie S40 Boom Lift (A64047)
Genie S40 Boom...
2008 28ft. Regal 2565 Express Cruiser Boat with 30ft T/A Continental Boat Trailer (A61569)
2008 28ft. Regal...
2002 Blue Bird F131612 Bus (A61568)
2002 Blue Bird...
Deere 35G (A62180)
Deere 35G (A62180)
2005 International 7600 Dump Truck, VIN # 1HTWYAHT15J055083 (A61165)
2005 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
