Kubota B7800
   / Kubota B7800 #1
Fire5980
Comanche, OK
Kubota B7800
Issue!!! I was mowing yesterday (brush hog), Hit a pile of dirt and the tractor died. Took the mower out of gear, pushed on clutch and tried to restart the engine. Nothing, Nothing. I turn on the key, instrument panel lights but the engine will not turn over or even click as if a battery is low.
Something in the ignition? Found my paper work from purchase and it has a "slow blow' fuse. Could this be my problem?????
Await an answer if you care to share.
Thanks,
Larry
   / Kubota B7800 #2
Probably just a safety switch. Check your power take off lever, if off a little bit it won't start. I had a kid playing on my tractor with it off of course and he moved the lever just enough so it would not start. Took me awhile to discover that.
   / Kubota B7800
Magicheater,
Thanks for the info. I will try that as soon as I get home. I appreciate your quick response.
Larry
   / Kubota B7800 #4
one other thing that came to my mind is to check the hst foot pedal. it also has to be in neutral to start and can sometimes throw fits. mine was off a bit once and took me a while to figure it out. maybe stalling the tractor while on the foot pedal might have not let it return to neutral normally. this probably is not it, but is worth a quick check. good luck.
   / Kubota B7800
Thanks Namesray, That is exactly what the problem was. I adjusted every lever, clutch, etc. While holding the key in the crank position I happen to step on the HST and the dang thing started. I just found this site and am very happy to get the help. Kuddo's to you and magicheater. Thanks,
Larry
   / Kubota B7800 #6
Since you narrowed it down to the HST pedal, give it a shot of grease. ;) Glad you are up and running!!:)
2015 JOHN DEERE 744K-II HIGH LIFT WHEEL LOADER (A51242)
2015 JOHN DEERE...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2016 FREIGHTLINER 2500 SPRINTER VAN (A51222)
2016 FREIGHTLINER...
Deutz-Allis GVL Poly Corn Head (A50514)
Deutz-Allis GVL...
2015 Volkswagen Jetta TDI Sedan (A50324)
2015 Volkswagen...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A51222)
2014 INTERNATIONAL...
