Kubota B7800 intermittent no start
   / Kubota B7800 intermittent no start #1
Bill Bauman
LACENTER WA
Kubota B7800
i have been having trouble starting my Kubota b7800. if i keep working the forawd reverse pedal for the hydrostat i can get it started. is there a safty switch that can be adjusted and where is it located i don't see it around the pedal area
   / Kubota B7800 intermittent no start #2
Bill I can't answer you question for sure but it really sounds like safety natural switch, I would follow linkage back to trans switch has to be somewhere, should be a two wire switch might be in trans housing. Sorry I could not be of more help.
   / Kubota B7800 intermittent no start #3
Don't forget to check your seat switch. Seems like there's been a rash of seat switches going bad lately.
   / Kubota B7800 intermittent no start #4
My B7800 has a switch located behind the pedal linkage. If you look underneath and find the pedal pivot(with a grease fitting on it) and follow linkage to the rear of the tractor you should find the switch. It is adjustable. B7800 linkage sticking is a common problem and if you search this forum you should find lots of info on it. Someone posted a good videao of it and if I can find the link I'll post it.
Barney
Here's the link. It's for a 3200 series but has the same type of set up as the B7800 and shows it pretty well.
Kubota b3200 sticking forward pedal / starting problem interlock - YouTube
   / Kubota B7800 intermittent no start #5
Barney
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
Concrete Bucket for Crane (A50860)
Concrete Bucket...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
8ft. Enclosed Cargo S/A Trailer (A48082)
8ft. Enclosed...
