Kubota B7800 intermittent no start
   / Kubota B7800 intermittent no start #1
Bill Bauman
LACENTER WA
Kubota B7800
i have been having trouble starting my Kubota b7800. if i keep working the forawd reverse pedal for the hydrostat i can get it started. is there a safty switch that can be adjusted and where is it located i don't see it around the pedal area
   / Kubota B7800 intermittent no start #2
Bill I can't answer you question for sure but it really sounds like safety natural switch, I would follow linkage back to trans switch has to be somewhere, should be a two wire switch might be in trans housing. Sorry I could not be of more help.
   / Kubota B7800 intermittent no start #3
Don't forget to check your seat switch. Seems like there's been a rash of seat switches going bad lately.
   / Kubota B7800 intermittent no start #4
My B7800 has a switch located behind the pedal linkage. If you look underneath and find the pedal pivot(with a grease fitting on it) and follow linkage to the rear of the tractor you should find the switch. It is adjustable. B7800 linkage sticking is a common problem and if you search this forum you should find lots of info on it. Someone posted a good videao of it and if I can find the link I'll post it.
Barney
Here's the link. It's for a 3200 series but has the same type of set up as the B7800 and shows it pretty well.
Kubota b3200 sticking forward pedal / starting problem interlock - YouTube
   / Kubota B7800 intermittent no start #5
Barney
EVERSMAN 600 HYD DIRT PAN (A50459)
EVERSMAN 600 HYD...
2014 Ford F-350 Altec AT200A Insulated Crane Service Truck (A48081)
2014 Ford F-350...
2 Yard Commercial Dumpster (A49346)
2 Yard Commercial...
6ft Tooth Bucket (A48837)
6ft Tooth Bucket...
275 Gallon Liquid Storage IBC Tote (A49346)
275 Gallon Liquid...
377840 (A48836)
377840 (A48836)
