Kubota B7100?or B6200D???
   / Kubota B7100?or B6200D???
As far as what is not pictured I couldn't say.
If you would like me to take some pictures of any particular part/area
let me know, and I will get them.
Jon
   / Kubota B7100?or B6200D??? #12
Okay ... the pix showing the engine does not look like the one my B7100. For one thing it appears you have a different generator/alternator. and the exhaust manifold appears somewhat different.
If I had to bet, I would say that you have basically a B7100 which has been fitted with a slightly different replacement engine and hood and ????.
The specs say that the B7100 has a Kubota D750-A engine.
Hope that helps
Sherweld
   / Kubota B7100?or B6200D??? #13
I think you have a combination of the two, If you do a advance search of my user name I have posted pictures of my B7100 HST, might help you some.
Casey
   / Kubota B7100?or B6200D??? #14
It definitely looks like a hybrid. The front frame on a B7100 is not as long as what shows in your picture. The B7100 hood hinges at the bottom just below the radiator. The fuel tank looks right for a 7100 (off on the left). To my knowledge, all 7100s had the D750 engine.
   / Kubota B7100?or B6200D??? #15
Frame looks right, engine looks too short, how many cylinders is it?
It's a 3 cyl diesel
I could look for a engine serial# if you like
   / Kubota B7100?or B6200D??? #17
The fuel tank and batt look exactly like mine. AF and fuel filter loook similar too but I'm not near the tractor right now so not 100% sure.
The pic of the tranny looks like mine too.
   / Kubota B7100?or B6200D??? #18
Here are a few photos of my B7100 jon. See if you can make some comparisons with your machine. If you need more photos, let me know.
There are diffidently a couple of differences that I notice right off
1. It looks like your tractor has a larger radiator
2. Mine has a water pump (in your photos It doesn't appear that your tractor
has a water pump but I might be wrong so please correct me if I am
2. On the dash of my tractor there is a label that reads "decompression knob"
but all there is, is a hole. As far as I can see there is no decomp option on my engine.
3. and as already noted the alternator is diffidently different
I am going to talk to the dealer I bought the tractor from and see if they can connect me with the original owner.
I will report what I figure out as soon as possible
Thank's everyone for your help, Jon
   / Kubota B7100?or B6200D??? #20
Looks like you have a piece meal tractor. The D850 engine appears to be used in many applications including welders. It's 15 or 17 HP according to a search I did. The B7100 is 16HP I think. Here's what the D850 goes in, B6200 is in the list.
B1550DT-----96-88---KUBOTA D850-5B 17HP DSL
B1550DTEX---96-88---KUBOTA D850-5B 17HP DSL
B1550HSD----97-88---KUBOTA D850-5B 17HP DSL
B1550HSDT---97-88---KUBOTA D850-5B 17HP DSL
B1550HSE----96-88---KUBOTA D850-5B 17HP DSL
B6200DT-----94-83---KUBOTA D850-5B 15HP DSL
B6200E-------94-83---KUBOTA D850-5B 15HP DSL
B6200HSD----94-83---KUBOTA D850-5B 15HP DSL
B6200HSDT---94-83---KUBOTA D850-5B 15HP DSL
B6200HSE----94-83---KUBOTA D850-5B 15HP DSL
B6200HST----94-83---KUBOTA D850-5B 15HP DSL
CATERPILLAR 336FL EXCAVATOR (A51242)
CATERPILLAR 336FL...
2007 KENWORTH T800 DUMP TRUCK (A51243)
2007 KENWORTH T800...
2021 CASE TV450B SKID STEER (A51242)
2021 CASE TV450B...
Blue Diamond Quick Attach 6 Way Blade (A50514)
Blue Diamond Quick...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52128)
2018 Dodge Ram...
2005 Ford F-150 Ext. Cab Pickup Truck (A50323)
2005 Ford F-150...
