Kubota B7100?or B6200D???
   / Kubota B7100?or B6200D???
As far as what is not pictured I couldn't say.
If you would like me to take some pictures of any particular part/area
let me know, and I will get them.
Jon
   / Kubota B7100?or B6200D??? #12
Okay ... the pix showing the engine does not look like the one my B7100. For one thing it appears you have a different generator/alternator. and the exhaust manifold appears somewhat different.
If I had to bet, I would say that you have basically a B7100 which has been fitted with a slightly different replacement engine and hood and ????.
The specs say that the B7100 has a Kubota D750-A engine.
Hope that helps
Sherweld
   / Kubota B7100?or B6200D??? #13
I think you have a combination of the two, If you do a advance search of my user name I have posted pictures of my B7100 HST, might help you some.
Casey
   / Kubota B7100?or B6200D??? #14
It definitely looks like a hybrid. The front frame on a B7100 is not as long as what shows in your picture. The B7100 hood hinges at the bottom just below the radiator. The fuel tank looks right for a 7100 (off on the left). To my knowledge, all 7100s had the D750 engine.
   / Kubota B7100?or B6200D??? #15
Frame looks right, engine looks too short, how many cylinders is it?
It's a 3 cyl diesel
I could look for a engine serial# if you like
   / Kubota B7100?or B6200D??? #17
The fuel tank and batt look exactly like mine. AF and fuel filter loook similar too but I'm not near the tractor right now so not 100% sure.
The pic of the tranny looks like mine too.
   / Kubota B7100?or B6200D??? #18
Here are a few photos of my B7100 jon. See if you can make some comparisons with your machine. If you need more photos, let me know.
There are diffidently a couple of differences that I notice right off
1. It looks like your tractor has a larger radiator
2. Mine has a water pump (in your photos It doesn't appear that your tractor
has a water pump but I might be wrong so please correct me if I am
2. On the dash of my tractor there is a label that reads "decompression knob"
but all there is, is a hole. As far as I can see there is no decomp option on my engine.
3. and as already noted the alternator is diffidently different
I am going to talk to the dealer I bought the tractor from and see if they can connect me with the original owner.
I will report what I figure out as soon as possible
Thank's everyone for your help, Jon
   / Kubota B7100?or B6200D??? #20
Looks like you have a piece meal tractor. The D850 engine appears to be used in many applications including welders. It's 15 or 17 HP according to a search I did. The B7100 is 16HP I think. Here's what the D850 goes in, B6200 is in the list.
B1550DT-----96-88---KUBOTA D850-5B 17HP DSL
B1550DTEX---96-88---KUBOTA D850-5B 17HP DSL
B1550HSD----97-88---KUBOTA D850-5B 17HP DSL
B1550HSDT---97-88---KUBOTA D850-5B 17HP DSL
B1550HSE----96-88---KUBOTA D850-5B 17HP DSL
B6200DT-----94-83---KUBOTA D850-5B 15HP DSL
B6200E-------94-83---KUBOTA D850-5B 15HP DSL
B6200HSD----94-83---KUBOTA D850-5B 15HP DSL
B6200HSDT---94-83---KUBOTA D850-5B 15HP DSL
B6200HSE----94-83---KUBOTA D850-5B 15HP DSL
B6200HST----94-83---KUBOTA D850-5B 15HP DSL
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A50323)
2012 Cottrell...
UNUSED AGT DM20 EXCAVATOR (A51243)
UNUSED AGT DM20...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
UNUSED MOWER KING ECSSCT72 TRENCHER (A51244)
UNUSED MOWER KING...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A52128)
2023 New Holland...
