Loader Kubota B6100D Front PTO ???
   / Kubota B6100D Front PTO ???
WVBill, I don't have a pump, Kubota or otherwise, yet, so the mount is something I will fabricate myself. I'll try my local Kubota dealer (and others) and see if I can get a roller chain coupling with an 18-22 spline sprocket. That alone will be a big step in the right direction. Thanks for your assistance.
Fred
Well instead of shortening the shaft, why not remove it? Use one sprocket of each chain coupling (one with the 18mm 22 spline and the sprocket with the keyed shaft for the pump, remove the shaft and both attached sprockets) and a single chain to connect the two. Failing that, cut and weld the shaft. My main problem was to locate an inside coupler with 18mm by 22 spline. That problem you have solved. Thanks.
Fred
2015 John Deere 544K Articulated Wheel Loader (A55973)
2015 John Deere...
2016 GENIE S-65 TELESCOPIC BOOM LIFT (A52709)
2016 GENIE S-65...
1996 Sunflower 1543-38 Folding Disk (A56435)
1996 Sunflower...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
