Loader Kubota B6100D Front PTO ???
   / Kubota B6100D Front PTO ???
WVBill, I don't have a pump, Kubota or otherwise, yet, so the mount is something I will fabricate myself. I'll try my local Kubota dealer (and others) and see if I can get a roller chain coupling with an 18-22 spline sprocket. That alone will be a big step in the right direction. Thanks for your assistance.
Fred
Well instead of shortening the shaft, why not remove it? Use one sprocket of each chain coupling (one with the 18mm 22 spline and the sprocket with the keyed shaft for the pump, remove the shaft and both attached sprockets) and a single chain to connect the two. Failing that, cut and weld the shaft. My main problem was to locate an inside coupler with 18mm by 22 spline. That problem you have solved. Thanks.
Fred
NEW Wolverine 36in Skid Steer Grapple Bucket (A59000)
NEW Wolverine 36in...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
2001 Freightliner MB55 Chassis Bus (A56858)
2001 Freightliner...
2023 PITTS LB35-33CS LOWBOY TRAILER (A58018)
2023 PITTS...
NEW Wolverine 72in Skid Steer Ripper (A59000)
NEW Wolverine 72in...
NEW Fork Extensions (A59000)
NEW Fork...
