Kubota b6000
   / Kubota b6000
Here is the next problem. My b6000 has a 10spline pto shaft the reverser takes a 18spline input. Any ideas please?
   / Kubota b6000 #13
I don't think they can. The 2 wheel drive version of the B6000 apparently came with a different, 10 spline output shaft than the 4 wheel drive version did, which uses an 18 spline unit. I have been told the parts are different internally as well, so cannot be swapped. It is possible that the Tisco adapter T355 Tisco Public Catalog MAY work for you. It is a 10 spline to conventional 6 spline PTO shaft adapter bushing. It is intended for the Farmall Cub machines and claims to fit Kubota. I do not know if this will work for you or not.
It would not get you to 18 splines for the PTO reverser either, but with the 6 spline 1 3/8" male end you can adapt or convert to whatever you need with some fabrication. To be honest, for a 2 wheel drive B6000, I would just sell it and buy something that will work without as much hassle, or else resign myself to only using non-powered implements.
   / Kubota b6000
My b6000 is a 4x4 with a 10 spline pto
   / Kubota b6000 #15
I don't know what to tell you then; I've never had my B6000 apart, and it came with a bushing adapting it to 6 spline 1 3/8" output. I have never counted the splines. I only know that the PTO shafts listed in Kubota's parts book have different part numbers for the B6000e and B6000, and that others with more experience and knowledge say the B6000e uses the 10 spline output shaft. Sorry.
   / Kubota b6000
Any help greatly would be appreciated. I have the b6000 and it has a 10 spline. I found a company that still makes the reverser but it takes the 18 spline. I don't know what to do.
Kubota SVL95-2 High Flow Cab Skid Steer (A52748)
Kubota SVL95-2...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
2014 Dodge Journey SUV (A50324)
2014 Dodge Journey...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2006 Hino 268 Truck, VIN # 5PVNJ81T962S11110 (A51572)
2006 Hino 268...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
