Kubota b6000
   / Kubota b6000
Here is the next problem. My b6000 has a 10spline pto shaft the reverser takes a 18spline input. Any ideas please?
   / Kubota b6000 #13
I don't think they can. The 2 wheel drive version of the B6000 apparently came with a different, 10 spline output shaft than the 4 wheel drive version did, which uses an 18 spline unit. I have been told the parts are different internally as well, so cannot be swapped. It is possible that the Tisco adapter T355 Tisco Public Catalog MAY work for you. It is a 10 spline to conventional 6 spline PTO shaft adapter bushing. It is intended for the Farmall Cub machines and claims to fit Kubota. I do not know if this will work for you or not.
It would not get you to 18 splines for the PTO reverser either, but with the 6 spline 1 3/8" male end you can adapt or convert to whatever you need with some fabrication. To be honest, for a 2 wheel drive B6000, I would just sell it and buy something that will work without as much hassle, or else resign myself to only using non-powered implements.
   / Kubota b6000
My b6000 is a 4x4 with a 10 spline pto
   / Kubota b6000 #15
I don't know what to tell you then; I've never had my B6000 apart, and it came with a bushing adapting it to 6 spline 1 3/8" output. I have never counted the splines. I only know that the PTO shafts listed in Kubota's parts book have different part numbers for the B6000e and B6000, and that others with more experience and knowledge say the B6000e uses the 10 spline output shaft. Sorry.
   / Kubota b6000
Any help greatly would be appreciated. I have the b6000 and it has a 10 spline. I found a company that still makes the reverser but it takes the 18 spline. I don't know what to do.
Ih 4300 Field Cultivator (A50514)
Ih 4300 Field...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
Delta Consolidated Fuel Tank 48000 (A51039)
Delta Consolidated...
2007 John Deere TX 4x2 Utility Gator (A49346)
2007 John Deere TX...
UTV (A49461)
UTV (A49461)
2018 FORD EXPEDITION (A51406)
2018 FORD...
