OP
wsessions1005
Here is the next problem. My b6000 has a 10spline pto shaft the reverser takes a 18spline input. Any ideas please?
I don't think they can. The 2 wheel drive version of the B6000 apparently came with a different, 10 spline output shaft than the 4 wheel drive version did, which uses an 18 spline unit. I have been told the parts are different internally as well, so cannot be swapped. It is possible that the Tisco adapter T355 Tisco Public Catalog MAY work for you. It is a 10 spline to conventional 6 spline PTO shaft adapter bushing. It is intended for the Farmall Cub machines and claims to fit Kubota. I do not know if this will work for you or not.
It would not get you to 18 splines for the PTO reverser either, but with the 6 spline 1 3/8" male end you can adapt or convert to whatever you need with some fabrication. To be honest, for a 2 wheel drive B6000, I would just sell it and buy something that will work without as much hassle, or else resign myself to only using non-powered implements.
