Kubota B3350 - Turbo Diesel or Not?
   / Kubota B3350 - Turbo Diesel or Not? #1
Verdemont
Greene, RI
2015 Kubota B2650 HST
I've seen several references to the new B3350 diesel engine being turbo charged. My dealer says it is not. I did a close inspection and could not see a turbo anywhere but it is tight under the hood with that gigantic pollution control canister up there. I Googled and even read the Kubota literature and don't see any reference to a turbo. I've already purchased a new B2650 so this is not a purchase decision, I'd just like to know. If there is a turbo, where is it?
Thanks,
Tom
   / Kubota B3350 - Turbo Diesel or Not? #2
Nothing I have seen shows it has turbo.
   / Kubota B3350 - Turbo Diesel or Not? #3
Could the references you refer to be confusing a turbo for the DPF...Diesel Particulate Filter? The B3350 has a DPF to meet the new emission standards, which has been giving some people headaches, but it is not and has never been turbo charged. The B2650 does not have a DPF, so unless you need the extra HP for larger PTO powered implements, the B2650 is the way to go!
   / Kubota B3350 - Turbo Diesel or Not? #4
The B3350 is definitely turbo charged.
V1505-T-E4-D26-Q is the engine designation. The T is for turbo charged aspiration. I have looked at the tractors and have seen the turbo which is buried under all the emission garbage.
   / Kubota B3350 - Turbo Diesel or Not? #5
My understanding, yes, the B3350 does have a turbo. I was looking seriously at them before purchasing the B2650. hjt
   / Kubota B3350 - Turbo Diesel or Not? #6
Yes on the turbo. Was at a dealer a few months ago, and even he didn't know that until I showed him the plumbing.
A few folks here have gone with the 3350 just to get the turbo for better power at high altitude. I guess it's good to have that option in the lineup.
All:
Thanks everyone. I used all of my Google Fu and could not find any mention of the turbo or a picture of the turbo ANYWHERE on the internet (I'm an IT guy). Yes, there is a T in the engine spec for the B3350.
The specs from the Kubota brochure:
B2650:
Cylinders: 3
Bore & Stroke: 3.1 x 3.5 (78 x 88)
Displacement: cu. in (cc): 77.0 (1261)
B3350:
Cylinders: 4
Bore & Stroke: 3.1 x 3.1 (78 x 78.4)
Displacement: cu. in (cc): 91.5 (1498)
Notes:
1. The B3350 has an engine displacement that is 18.8% larger than the B2650
2. The B3350 has the same bore, an extra cylinder, but a different stroke than the B2650, i.e. it's not just a 4 cylinder version of the B2650 engine (turbo or not)
3. The rated engine HP difference (per Kubota) for the B3350 is 33 HP versus 26 HP for the B2650 which is a 27% increase.
4. The HP ratings for both engines are at 2500 RPM.
Thus.....
It sure seems like there MUST be a turbo on the B3350 as the increase in HP over the B2650 is 27% while the displacement only increases by 18.8%. The shorter stroke of the B3350 certainly can't account for it I don't think. Interesting that the stroke on the B2650 is longer.
I am even MORE glad now that I went with the B2650. Besides the fact that I don't have the regen and extra plumbing, I don't have a turbo to worry about. I live at 600 feet above sea level now, so I don't need the turbo to stuff the air in for me. Turbo's are another item that can and do wear out and cost more money to replace. I don't want a turbo tractor unless I really NEED a turbo tractor.
Tom
   / Kubota B3350 - Turbo Diesel or Not? #8
I just went to Kubota's website and tried to build a B3350 with turbo. Turbo is not an option you can get.
   / Kubota B3350 - Turbo Diesel or Not? #9
It's not an option , it's the only way you can get the tractor.
NEW Fork Extensions (A53002)
NEW Fork...
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A52141)
2004 HYUNDAI...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2012 Chevrolet Captiva Sport SUV (A50324)
2012 Chevrolet...
