Kubota B3200??
/ Kubota B3200?? #2
You'll probably see it at your dealer before it appears on the web site.
/ Kubota B3200?? #3
bh76?
/ Kubota B3200?? #5
Position Control?
New engine or tweaked B3030 engine or....?
Would this be the B7800's replacement?
/ Kubota B3200??
A little frustrating when just bought a b2920 and thi model comes out a few months later.
ericher69
/ Kubota B3200?? #9
Just curious if anyone has purchased the new 3200? I am looking at upgrading and haven't had an opportunity to view on a dealer lot. I understand they are just appearing on dealer lots but haven't seen spec's; pricing; etc. Any information appreciated.
Thanks. Brent
/ Kubota B3200?? #12
I talked to a near-by dealer and the salesman said B3200 will cost about $1000-1200 more then the B7800 price. He said that the engines in the newer tractors are designed to run at a higher RPM so they get cleaner emissions. Other than that the major difference is in styling. I don't know if it is the same engine as the one in the 7800.
/ Kubota B3200?? #13
here are the details...
DIESEL ENGINE​
Model # V1505-E3-D24
4 Cyl. 91.5 cu. In.
+ 32 Gross Eng. HP
+ 23.0 PTO HP
@ 2700 Eng. Rpm
12V - 36 Amp Hour Battery
Charging Output 14.5 Amps​
HYDRAULICS​
Open Center Gear Type
3.2 gpm Power Steering
6.7 gpm Remote/3 Pt. Hitch
9.9 gpm Total Hyd. Flow
Cat I 3-point Hitch
At lift Point 1655 lbs.
24” Behind 1300 lbs.​
FRONT AXLE​
Integral Power Steering
Cast Iron
Bevel Gear, 4WD
Tread Spacing, Nonadjustable
+ Manufacturer estimate.​
TRANSMISSION​
Hydrostatic Drive
Forward Speeds
Hi Range 0 – 12.4 mph
Med. Range 0 – 5.8 mph
Lo Range 0 – 3.3 mph
Reverse Speeds
Hi Range 0 – 9.9 mph
Med. Range 0 – 4.5 mph
Lo Range 0 – 2.6 mph
Rear Differential Lock​
FLUID CAPACITY​
Fuel Tank 8.1 gal.
Cooling System 4.7 qts.
Crankcase 5.7 qts.
Transmission and 15.3 qts.
Hydraulics​
POWER TAKE OFF​
Live Continuous Running Rear
Mid PTO
Rear PTO – 1 Speed
SAE Std 1 3/8” Six Spline
540 rpm @ 2600 Eng. rpm
Mid PTO – 1 Speed
2500 rpm @ 2578 Eng. rpm
Operator Presence Control System​
SAFETY EQUIPMENT​
2-Post ROPS w / Retractable
Seat Belt
Flip-Up PTO Shield
Safety Start Switches
Electric Key Shut Off
Wet Disc Brakes
Parking Brakes​
TIRES AND WHEELS​
Front 180/85 D12 R1​
Rear 12.4 x 16 R1
/ Kubota B3200?? #15
Just signed the paper for a new B3200 with 4in1 bucket and backhoe.
should have it before the end of the year. I will post pics when they deliver.
I am a new member, look forward to some quality time on this forum.:)
/ Kubota B3200?? #19
What would be a good price for a B3200 with loader? 60" MMM? Backhoe w/12" bucket?
/ Kubota B3200?? #20
You mean like this? Go to Kubota. com and do a build my Kubota, you can add most options and see the price. Perfect size Tractor for me, right size and power, Good Luck
2023 Kubota M5-091D 4WD 92HP Utility Loader Tractor (A66734)
2023 Kubota...
2012 Bush Hog Flail (A64911)
2012 Bush Hog...
3pt Ditcher (A64911)
Year: 2018 Make: GMC Model: Terrain Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 116,222 Pla... (A66738)
Year: 2018 Make...
PORTA POTTY (A68842)
Yale GLC040AFNUAF082 Warehouse Forklift (A64911)
Yale...
