Kubota B3200??
/ Kubota B3200?? #2
You'll probably see it at your dealer before it appears on the web site.
/ Kubota B3200?? #3
bh76?
/ Kubota B3200?? #5
Position Control?
New engine or tweaked B3030 engine or....?
Would this be the B7800's replacement?
/ Kubota B3200??
A little frustrating when just bought a b2920 and thi model comes out a few months later.
ericher69
/ Kubota B3200?? #9
Just curious if anyone has purchased the new 3200? I am looking at upgrading and haven't had an opportunity to view on a dealer lot. I understand they are just appearing on dealer lots but haven't seen spec's; pricing; etc. Any information appreciated.
Thanks. Brent
/ Kubota B3200?? #12
I talked to a near-by dealer and the salesman said B3200 will cost about $1000-1200 more then the B7800 price. He said that the engines in the newer tractors are designed to run at a higher RPM so they get cleaner emissions. Other than that the major difference is in styling. I don't know if it is the same engine as the one in the 7800.
/ Kubota B3200?? #13
here are the details...
DIESEL ENGINE​
Model # V1505-E3-D24
4 Cyl. 91.5 cu. In.
+ 32 Gross Eng. HP
+ 23.0 PTO HP
@ 2700 Eng. Rpm
12V - 36 Amp Hour Battery
Charging Output 14.5 Amps​
HYDRAULICS​
Open Center Gear Type
3.2 gpm Power Steering
6.7 gpm Remote/3 Pt. Hitch
9.9 gpm Total Hyd. Flow
Cat I 3-point Hitch
At lift Point 1655 lbs.
24” Behind 1300 lbs.​
FRONT AXLE​
Integral Power Steering
Cast Iron
Bevel Gear, 4WD
Tread Spacing, Nonadjustable
+ Manufacturer estimate.​
TRANSMISSION​
Hydrostatic Drive
Forward Speeds
Hi Range 0 – 12.4 mph
Med. Range 0 – 5.8 mph
Lo Range 0 – 3.3 mph
Reverse Speeds
Hi Range 0 – 9.9 mph
Med. Range 0 – 4.5 mph
Lo Range 0 – 2.6 mph
Rear Differential Lock​
FLUID CAPACITY​
Fuel Tank 8.1 gal.
Cooling System 4.7 qts.
Crankcase 5.7 qts.
Transmission and 15.3 qts.
Hydraulics​
POWER TAKE OFF​
Live Continuous Running Rear
Mid PTO
Rear PTO – 1 Speed
SAE Std 1 3/8” Six Spline
540 rpm @ 2600 Eng. rpm
Mid PTO – 1 Speed
2500 rpm @ 2578 Eng. rpm
Operator Presence Control System​
SAFETY EQUIPMENT​
2-Post ROPS w / Retractable
Seat Belt
Flip-Up PTO Shield
Safety Start Switches
Electric Key Shut Off
Wet Disc Brakes
Parking Brakes​
TIRES AND WHEELS​
Front 180/85 D12 R1​
Rear 12.4 x 16 R1
/ Kubota B3200?? #15
Just signed the paper for a new B3200 with 4in1 bucket and backhoe.
should have it before the end of the year. I will post pics when they deliver.
I am a new member, look forward to some quality time on this forum.:)
/ Kubota B3200?? #19
What would be a good price for a B3200 with loader? 60" MMM? Backhoe w/12" bucket?
/ Kubota B3200?? #20
You mean like this? Go to Kubota. com and do a build my Kubota, you can add most options and see the price. Perfect size Tractor for me, right size and power, Good Luck
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2017 Ford Explorer SUV (A66738)
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2004 John Deere 8320 (A63688)
2004 John Deere...
