Quick Hitches Kubota B2920
/ Kubota B2920 #1
Watercarving
Kubota b2920
Already considering a three-point quick hitch. Any recommendations?
Thanks.
/ Kubota B2920 #2
A quick hitch of some kind is definitely a must. You can search on this site and get tons of info. I went with a cheap online version for a hundred bucks and works with everything except the brush hog. Worth it's weight in gold just for saving my sanity while putting the boxblade on.
/ Kubota B2920
Why does your bush hog not work? Are there quick hitches that will work with a bush hog?
/ Kubota B2920 #4
I've got a SpeeCo that I bought at Tractor Supply. I removed the bolts that hold the hook on it and replaced them with pins, so that I can move the hook up and down quicker.
The hitch works with my John Deere JX4 rotary cutter but I have to reposition the hook because it won't work in the same spot that it's in for the snowblower.
http://www.tractorsupply.com/quick-hitch-cat-1-0267563
/ Kubota B2920 #5
Unfortunately not all Cat 1 equipment is made to the same dimensional spec for the top link connection. Some are easily adjustable and others require torch and welder.
/ Kubota B2920 #6
I got something similar to a Pats and the hooks that go on the arms are just slightly too big to get under the brush hog pins due to a lip on the front of the brush hog.
I keep it on an oversized pallet with a piece of plywood on top so I can slide it around which makes it much easier than moving it around on the ground.
/ Kubota B2920 #7
Thanks.
I have a 2920 and use the Land Pride Quick Hitch on mine. I think it works very well. The one issue that I had from it was that I bought it after I bought my tractor and bush hog. The QH set the BH back about 4 inches, which was not an issue until I started to BH my dam. When doing this, I have the tractor on top of the dam, and I back the BH over the side of the dam to do the slope, which puts the BH far below the tractor and lengthens the shaft considerably. I found my shaft was then not long enough. It never separated, but vibrated in the middle like mad, and the protective pipe over it separated so that when I pulled the BH back up level, the pipe tried to come together and mashed against each other. I brought this up with my dealer and ended up buying a little longer drive shaft for the BH.
I'm not satisfied with the approach on this though, as I see that Messics sells drive shaft extensions and for $35 I could have bought a extension. Far cheaper then buying a new drive shaft.
Overall, I've been very satisfied with my Land Pride Quick Hitch.
Larry
24" X 84" METAL SHELVES (A63745)
24" X 84" METAL...
2025 Intersate Fabrique 12' x 6' Dump Trailer (A62613)
2025 Intersate...
1100 GAL FLAT BOTTOM POLY STORAGE TANK (A63745)
1100 GAL FLAT...
2012 Ford F250 Service Truck 4X4 (A64047)
2012 Ford F250...
6 Row Harrell Stalk Chopper (A62177)
6 Row Harrell...
2022 John Deere 5055E (A60462)
2022 John Deere...
