Kubota B2920 3 point hitch and FEL issue with hydraulic operation
   / Kubota B2920 3 point hitch and FEL issue with hydraulic operation #11
Was the dealer taking about the feedback adjustment? It's real easy to adjust and if you have a manual it's in there with pictures.
   / Kubota B2920 3 point hitch and FEL issue with hydraulic operation #12
Probably. He didn't use those terms. I see a rod with a spring that looks like it is supposed to do that. I'll check the manual later when I get a chance. For now I can deal with it.
   / Kubota B2920 3 point hitch and FEL issue with hydraulic operation #13
Yes, if you raise the handle to lift and hold there, the feedback mechanism should kick the lever back to neutral when the 3-pt arms are at the top of their range. I recall it sticking one time on my 2920, and a shot of lube got it right. But there is also an adjustment if the mechanism needs tweaking.
   / Kubota B2920 3 point hitch and FEL issue with hydraulic operation #14
Ok thanks. I'll check it out.
2014 Fiat 500L Hatchback (A48082)
2014 Fiat 500L...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A51039)
Kubota 24in Quick...
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2013 ACURA ILX (A50324)
2013 ACURA ILX...
2011 Ford Crown Victoria Sedan (A48082)
2011 Ford Crown...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
