Kubota B2920 3 point hitch and FEL issue with hydraulic operation
   / Kubota B2920 3 point hitch and FEL issue with hydraulic operation #11
Was the dealer taking about the feedback adjustment? It's real easy to adjust and if you have a manual it's in there with pictures.
   / Kubota B2920 3 point hitch and FEL issue with hydraulic operation #12
Probably. He didn't use those terms. I see a rod with a spring that looks like it is supposed to do that. I'll check the manual later when I get a chance. For now I can deal with it.
   / Kubota B2920 3 point hitch and FEL issue with hydraulic operation #13
Yes, if you raise the handle to lift and hold there, the feedback mechanism should kick the lever back to neutral when the 3-pt arms are at the top of their range. I recall it sticking one time on my 2920, and a shot of lube got it right. But there is also an adjustment if the mechanism needs tweaking.
   / Kubota B2920 3 point hitch and FEL issue with hydraulic operation #14
Ok thanks. I'll check it out.
Off-Road Buggy (A50860)
Off-Road Buggy...
WHITE CI-7 DRAW WORKS POWERED BY TWIN DETROIT 12.7S (A50854)
WHITE CI-7 DRAW...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
2014 Ford Escape SE SUV (A48082)
2014 Ford Escape...
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
