Kubota B2650
/ Kubota B2650 #1
ZZZ2D1
PRUDENVILLE, MI
2005 JOHN DEERE 4115 SOLD - 2014 NEW KUBOTA B2650 - AND - 2011 KUBOTA RTV 1100
Do any of the members put the kubota B2650 in their garage with standard door openings?
/ Kubota B2650 #2
With R4 tires, I'm positive you can fit it into a garage with a 7' tall door (so as long as the opening measures 84".) It should allow for an inch or two of clearance. With turf or R1 tires, it might be tight though since those tires are larger in diameter than the R4's.
I know this, because I went through all this earlier in the year (I was actually going to purchase the B3350.) I even went as far as re-framing the opening to my garage to get an extra two inches, but at the last moment I decided not to buy the B3350 and ended up purchasing an L4760 instead (ironically there's no chance of fitting this in my garage, so I'm going to be building a new storage shed for it! :)
Good luck!
/ Kubota B2650 #3
My B2320 does NOT fit through, with R4 tires, unless I lower the ROPS. It would fit, just gently rubbing, but the door has a 3/4" furring strip which holds the weather sealing strip against the door. I replaced the weather stripping piece last year. Had to, as I took it clean off, if you know what I mean. All it takes is forgetting one time.
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
John Deere 2155 (A62177)
John Deere 2155...
2022 EZ-GO ELITE...
2016 Ford F250 Crew Cab Service Truck (A64194)
2016 Ford F250...
2010 John Deere 1770NT Planter (A63109)
2010 John Deere...
