Kubota B2601 vs TYM T25
/ Kubota B2601 vs TYM T25 #1
KennyH
None yet
Currently looking at these two tractors. I’m looking for something that will not tear up my yard. It will be used to help with yard work and to occasionally spread dirt or gravel. May do some occasional light farm work but have a larger JD for that. Both tractors have good dealer support.
They each have positives and negatives. Kubota is $5k more but should have better resale. It also has a 3 speed transmission and T25 is 2 speed. The TYM seems a touch bigger and is a little heavier. Prefer the foot pedals on the T25. Kubota seems to have smoother loader control.
Does anyone have any experience with both of these or any suggestions on others that are similar size I should look at? Do you guys the the Kubota would be worth the extra $5k?
/ Kubota B2601 vs TYM T25 #2
How is the dealer support in your area on both brands?
They are both good machines, but any brand is subject to having something break, so dealer support is critical.
Personally I lean towards the T25 especially for 5k in savings.
Dealer support would be good for either. I know the owner of the TYM store well. He’ a smaller dealer that hasn’t been dealing tractors as long but he will bend over backward for people. Kubota dealer is larger dealer that has been around longer. I don’t know them as well but they have a good reputation. Bought a mower from them years ago and they treated me well with that.
/ Kubota B2601 vs TYM T25 #4
That's tough.
The Kubota is going to have solid parts support behind it, a massive dealer network, and arguably better fit and finish. Plus, now that I've had a 3 range hydro, I can't imagine going back to 2.
On the flip side the B2601 is a little less capable, and the T25 has proven itself as a really reliable little tractor. TYM sells quite a few of them, and I was personally impressed with the little tractor after messing around with it for a bit at a dealer open house when it was introduced.
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
Auger Drill Bit Skid Steer Attachment (A61572)
Auger Drill Bit...
2011 John Deere 9770 (A64119)
2011 John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2012 Ford F-150...
