Kubota B1750 won't go forward
   / Kubota B1750 won't go forward #1
stephengriger
Kuboto B1750
So I was moving snow yesterday and my B1750 stopped going forward. It will still go in reverse, but when you push the peddle to go forward, it just sinks down.
It looks like all of the linkages are attached, so I am curious if anybody else has had a similar problem or has any ideas about what to check.
   / Kubota B1750 won't go forward #2
parking brake ?
   / Kubota B1750 won't go forward #3
"Sinks down?" Do you mean stalls the engine?
no, like no response from the peddle. it goes on reverse, but when you press the peddle forward nothing happens.
   / Kubota B1750 won't go forward #6
Did you check your fluid level?
My B7610 started doing similar but worked better after warming up. My fluid level was fine.
   / Kubota B1750 won't go forward #7
I would inspect the mechanical connections between the pedal and the transmission again.
Does the pedal "feel" normal when pressing it for forward motion?
SDT
the peddle feels soft when pushing it forward, like a brake paddle when a line bursts.
I'm going to try cleaning the screens and checking our the hydro fluid. I checked the linkages again, but they all look good
   / Kubota B1750 won't go forward #9
Expect something in linkage, external or internal.
SDT
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
1837 (A58374)
1837 (A58374)
EXCAVATOR QUICK DISCONNECT (A58214)
EXCAVATOR QUICK...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
