Kubota B1750 won't go forward
   / Kubota B1750 won't go forward #1
stephengriger
Kuboto B1750
So I was moving snow yesterday and my B1750 stopped going forward. It will still go in reverse, but when you push the peddle to go forward, it just sinks down.
It looks like all of the linkages are attached, so I am curious if anybody else has had a similar problem or has any ideas about what to check.
   / Kubota B1750 won't go forward #2
parking brake ?
   / Kubota B1750 won't go forward #3
"Sinks down?" Do you mean stalls the engine?
no, like no response from the peddle. it goes on reverse, but when you press the peddle forward nothing happens.
   / Kubota B1750 won't go forward #6
Did you check your fluid level?
My B7610 started doing similar but worked better after warming up. My fluid level was fine.
   / Kubota B1750 won't go forward #7
I would inspect the mechanical connections between the pedal and the transmission again.
Does the pedal "feel" normal when pressing it for forward motion?
SDT
the peddle feels soft when pushing it forward, like a brake paddle when a line bursts.
I'm going to try cleaning the screens and checking our the hydro fluid. I checked the linkages again, but they all look good
   / Kubota B1750 won't go forward #9
Expect something in linkage, external or internal.
SDT
Toro 880 Procore (A55758)
Toro 880 Procore...
3PT DRAG HARROW (A52708)
3PT DRAG HARROW...
New/Unused 8in Bucket (A57454)
New/Unused 8in...
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
9000 (A47477)
9000 (A47477)
