Kubota B front tie down brackets
/ Kubota B front tie down brackets #1
Engine Mike
Rochester hills michigan
Kubota B2320
First time to haul my Kubota B. Does anyone know where to buy front tie down brackets for chains. I will tie the rear down with chains through the Clevis at the drawbar. Need to purchase from brackets and know where they attach.
/ Kubota B front tie down brackets #2
I used to use straps, with hooks. The hooks could be hung from the front frame crossmember on the tractor (it's where a snow blade would bolt on if you had one).
/ Kubota B front tie down brackets #3
Do you have room to drill and bolt on some D rings. That's what I added for tie downs.
