Kubota accesories
   / Kubota accesories #11
I am gonna pick up my new L2501/loader/backhoe combo in a couple of weeks. Its my first tractor, Ive since learned I need a 3rd function added to run a grapple, I would have thought that the dealer would have tried to sell me everything under the sun including the simonize but no, he even suggested I not buy the backhoe cause of cost.
He has ( as he says ) built my tractor already.
Is it too late to have some accessories added without getting assraped cause now they have to go back and undo some thing they have done to add the loader and backhoe?
I also would like a bucket level indicator added cause Ive read its a good thing to have.
Is there anyplace online that I can get an idea of the cost of these accessories ( just the Ill install it myself out the door price ) so that I can get an idea of what I should expect cost wise before I contact dealer?
Also dont forget about things you need to service the tractor and common tools you will likely need around.
Grease gun, extra 3 pt pins, chain for pulling with that drawbar. if you are doing the 50 hr service...filters, fluids. Others here https://www.tractorbynet.com/forums...t-have-tools-equipment-new-3.html#post5223088
   / Kubota accesories #12
R4. If he is charging me for the installs I don't expect it to be out of line.
Good tip on the grab bar, I may get that later
Congrats on the new tractor and enjoy it. :drink: Post a pic once you have it delivered.
   / Kubota accesories #13
Not really going to break the bank but I would add a knob for the steering wheel. The Kubota one seams good quality other than the orange color faded. Probably only $25 but well worth it and maybe the dealer will throw it in for free.
   / Kubota accesories #14
   / Kubota accesories #15
I think you mean the draw bar that is attached to the frame and not the 3pt hitch? If you use the 3pt hitch to haul trailers, please read up on the hazards of this so you know what you are dealing with. All OEM's will tell you the safest way to haul anything is with the tractor draw bar attached to the frame. Get them to weld bucket hooks on for you, they come in very handy.
   / Kubota accesories #16
A lot of operators install trailer balls on other implements like box blades, carry all's etc... I have one on my boom pole which is the handiest...dedicated 3ph receiver hitches are quite popular but cost a bit more than a 3ph drawbar bracket...
If you're pulling stumps or yanking on other deadweight objects the tractor (not 3ph) drawbar is the ticket...as it is below the axle and can prevent flipping...on many CUTs, SCUTs it would be impractical to try to tow a trailer from the tractor drawbar...
   / Kubota accesories #17
I agree the 3pt hitch and ball has it's uses. Don't forget though there is no weight holding the 3pt hitch down if you are hauling a trailer. If the load shifts to the back, the 3pt hitch will raise, possible flipping the trailer. Never haul a wagon with people in it by the 3pth hitch because of this.
   / Kubota accesories
Quote: Never haul a wagon with people in it by the 3pth hitch because of this.
Not even the wife :D
   / Kubota accesories #19
Ha, I mentioned this because I have heard of horror stories of people using tractors for hayrides around Halloween and accidents have happened.
Lincoln Electric Vantage 300 Welder/Generator (A49461)
Lincoln Electric...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
2017 Peterbilt 567 Tri-Axle Dump Truck (A49461)
2017 Peterbilt 567...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A51039)
Gooseneck...
2011 MAGNUM PRODUCTS LIGHT TOWER/WATER TANK TRAILER (A50854)
2011 MAGNUM...
2000 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A49461)
2000 Ingersoll...
