Kubota 900
/ Kubota 900 #2
According to the RTV1100 manual, these points. And the 900 series is almost identical.
/ Kubota 900 #3
I didn't see the grease fittings in the universal joints (rear) of the RTV 900 among Spudhauler's images. They may be there, but I didn't see them.
Steve
/ Kubota 900 #4
Good point!
No my manual didn't show them either.
There is one grease nipple on the rear u-joint but nothing on the front of my RTV1100 2009.
/ Kubota 900 #5
And they aren't easy to get at if your 1100 is like my 900. I use a floor jack to lift the rear end and rotate the tires in order to access the zerks.
Steve
/ Kubota 900 #6
I had to go check my RTV 900 and it for sure doesn't have any zerks on the rear U-Joints, likely this is only an 1100 thing. Good thing because I had never looked to grease there. I believe Messick's has a web page on servicing the RTV 900 which is what I used on mine. IT is pretty good at explaining what and where everything is located.
/ Kubota 900 #7
Gary,
You are correct -- Messick's site (Kubota : RTV-Series) does not mention the U-joints. However, my RTV 900 (purchased new in 2009) has zerks in the rear U-joints.
Steve
/ Kubota 900 #8
My 2011 RTV900 has a zerk for each u-joint. Total of four plus for more for the hydrostat linkages.
UNUSED ATS CMR1280 ELE.CEMENT MIXER (A62131)
UNUSED ATS CMR1280...
UNUSED WOLVERINE R-31-G1.5T 1R RIPPER (A62131)
UNUSED WOLVERINE...
JOB BOX (A62130)
JOB BOX (A62130)
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
UNUSED RAYTREE RMA42 HYD AUGER (A62131)
UNUSED RAYTREE...
Linde H35D 4,350lb. Diesel Forklift (A61567)
Linde H35D...
