Kubota 900
/ Kubota 900 #2
According to the RTV1100 manual, these points. And the 900 series is almost identical.
/ Kubota 900 #3
I didn't see the grease fittings in the universal joints (rear) of the RTV 900 among Spudhauler's images. They may be there, but I didn't see them.
Steve
/ Kubota 900 #4
Good point!
No my manual didn't show them either.
There is one grease nipple on the rear u-joint but nothing on the front of my RTV1100 2009.
/ Kubota 900 #5
And they aren't easy to get at if your 1100 is like my 900. I use a floor jack to lift the rear end and rotate the tires in order to access the zerks.
Steve
/ Kubota 900 #6
I had to go check my RTV 900 and it for sure doesn't have any zerks on the rear U-Joints, likely this is only an 1100 thing. Good thing because I had never looked to grease there. I believe Messick's has a web page on servicing the RTV 900 which is what I used on mine. IT is pretty good at explaining what and where everything is located.
/ Kubota 900 #7
Gary,
You are correct -- Messick's site (Kubota : RTV-Series) does not mention the U-joints. However, my RTV 900 (purchased new in 2009) has zerks in the rear U-joints.
Steve
/ Kubota 900 #8
My 2011 RTV900 has a zerk for each u-joint. Total of four plus for more for the hydrostat linkages.
Forks and Frame Mini Skid Steer Attachment (A61572)
Forks and Frame...
Bulk Lot - Atlas Copco Pump End Components (3) Pallets - Selling as One Lot (A63689)
Bulk Lot - Atlas...
Street Sweeper (A60352)
Street Sweeper...
2022 CATERPILLAR 299D3 XE SKID STEER (A64279)
2022 CATERPILLAR...
2012 VOLVO ROAD TRACTOR (A64280)
2012 VOLVO ROAD...
29 x 9.0 x 15 Tires with 5 Lug Wheels (A61573)
29 x 9.0 x 15...
