Kubota 8540 gearbox pressure/heat
   / Kubota 8540 gearbox pressure/heat #1
MarkMCM
Arlington, TX
MF 275
M8540 3007 3800 hours
After running a seed drill for a couple of hours (drill raise and lower at end of each pass), checked hydraulic fluid.
When I pulled the dipstick, a geyser of hydraulic fluid shot out until I put the dipstick back in. Rear case was hot enough to melt the filler cap. Engine temp normal.
Thoughts?
   / Kubota 8540 gearbox pressure/heat #2
First thought is did you have one of remote levers locked in detent position or 3 point asking for raise all the time. Either of these would keep pump at relief pressure creating heat.
This based on your tractor having a gear pump.
   / Kubota 8540 gearbox pressure/heat #3
Pull type or 3 pt ? It’s easy to pop a remote lever into detent and not notice especially on a turn around trying to get lined up.
Thanks guys. I done that before with the detent. I didn't think I was today. I will run the drill again with that in mind.
Appears to have been the ham fisted operator and the detent. Will see how it goes.
Thanks.
   / Kubota 8540 gearbox pressure/heat #6
Glad it was a simple fix.
JOHN DEERE 3033R LOT NUMBER 225 (A53084)
JOHN DEERE 3033R...
2007 Ford Crown Victoria Passenger Car, VIN # 2FAFP71W97X154872 (A51572)
2007 Ford Crown...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2025 Star EV Capella Electric Low speed Golf Cart (A51694)
2025 Star EV...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
Lift Gate (A52377)
Lift Gate (A52377)
