Oil & Fuel Kubota 6040
/ Kubota 6040 #1
Cid952
Dandridge, tn
Kubota 6040
I have a Kubota 6040 with less than 300 hours, just recently it started to act like it was running out of fuel. I have changed the fuel filter, and that did not help. Next I drained the fuel tank and cleaned it. The tractor ran good for about 3 hours then started again like its running out of fuel. After it sets for a little while it runs good for a few mins. I hope someone can help.
/ Kubota 6040 #2
Check that your tank is venting, either the cap is vented or there will be a vent line on it some where. Does it have more than one fuel filter. It might have a pre filter on it too.
/ Kubota 6040 #4
Did you clean the water seperator screen while changing fuel filter?? On RH side behind engine is a check valve in the fuel return to tank line. I would suggest to take it loose and see if engine will run correctly. I will clarify this statement as my M7040 and the M4900 I once owned both had this check valve so I presume your tractor does also.
BAKER HUGHES ELECTROSPEED 3 (A65643)
BAKER HUGHES...
2011 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2011 FOREST RIVER...
25 Traffic Cones (A65583)
25 Traffic Cones...
New Westinghouse Generator (A62613)
New Westinghouse...
2005 MACK CHN613 (A65643)
2005 MACK CHN613...
2025 Grapple Rake Mini Excavator Attachment (A64553)
2025 Grapple Rake...
