Kubota 5100E Implement options
/ Kubota 5100E Implement options #1
dergrah
Hi,
I don't know alot about tractors and am about to buy a really clean kubota 5100E unit. It has a puma-48 snow blower. I want to buy a box blade for it and am trying to figure out if I need a cat 0 or Cat 1 blade. The website for the puma-48 snow blower says its a Cat 1 but the 5100E is on 12hp. I'm also wondering if I'll have enough traction as it's only a 2WD unit.
The seller also has a midmount mower unit but it's for a kubota 7100. Would you think it could be modifed to fit the 5100 ? Will I have any luck finding the right midmount mower ? I can't justify cost of the rear PTO type.
Thanks,
Derek
Ottawa Canada
/ Kubota 5100E Implement options #3
Derek…
Don’t know if you will have enough tractor for what you are planning… most MMM are driven with a 1000 RPM PTO, rear PTO is usually 540RPM.
I see your new to the forum, welcome to the group. KennyV
Thanks for the info. I do have a two speed PTO rated at 12hp. I wonder what the other speed is ? Looking at the tractor this morning I don't think it has a MM-PTO.
Derek
/ Kubota 5100E Implement options #5
You should use cat 1 implements. You just need to buy "small" or "light" ones. Some of the manufacturors make a "sub-compact" line of attachments... such as King Kutter's XB line... those would suit you well.
Well today I picked up a 48" Box blade. Works good for leveling our the driveway. Got it to spread topsoil on my lot. I don't have enough traction to realy use the diggers. I almost bought a blade for it too. I have a loaner blade that I have been doing some good work with. I now see the two have a use and will pick up a new blade next week. I wish I hade more traction but for the price i couldn't go wrong.
Winter should be fun with the snow blower and snow blade it came with.
I think I will just pick up a riding mower ( can't call them a tractor now that I know what a real one is) when I have grass later this year.
/ Kubota 5100E Implement options #7
dergrah said:
Hi,
Thanks,
Derek
Ottawa Canada
The mmm for a 5100E is driven off of a front-mounted, electric clutch, PTO. There's a long v-belt that goes around a pulley on the front of th tractor and then gets routed down under and onto the mower. I don't imagine it would be too easy to find one. And even if you did, I wouldn't recommend it.
Your idea to pick up a lawn tractor is sound - either that or get a rear mower.
2012 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2012 FORD F150...
LEEBOY  1000 PAVER (A67714)
LEEBOY 1000 PAVER...
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
2006 JOHN DEERE 310G BACKHOE (A65053)
2006 JOHN DEERE...
2013 CHEVROLET 2500 HD (INOPERABLE) (A67714)
2013 CHEVROLET...
2015 CHEVROLET CAPRICE (A66091)
2015 CHEVROLET...
