Kubota 4240 ?
/ Kubota 4240 ? #1
closs2sx
Do you think a 4240 with quick attach forks will lift 1879 lbs I have to unload my Fort Knox in a week or so and if I need plan b I want to know now thanks for the help
/ Kubota 4240 ? #2
Dang! If you're moving gold bullion with a Kubota, well, you gotta take pictures.
The 4240 has the 854 FEL? 854 x 2.2 (lbs/kg) = 1878.8... say ... is this a joke?
/ Kubota 4240 ?
No joke specs say 2489 at pivot but I don't know what it will lift with forks never weighed what I have picked up just know my new safe is 1879 and I heard the hydraulics are turned down some from full operating pressure hoping I can lift it
/ Kubota 4240 ?
Thanks if I have to I will turn up the relief valve. Just stopped at the local dealer he said I should be good
/ Kubota 4240 ?
Feds need to worry about our economy 1st but they can't get that right either
/ Kubota 4240 ? #7
Too close to call. You'll need mucho rear counterweight. Is it laid horizontal or standing upright? Big gamble because if you drop it, you'll probably do some damage to something.
/ Kubota 4240 ?
tires are loaded and I have a bh80x backhoe on the back should be fine as far as ballast goes
/ Kubota 4240 ? #9
Oh with the backhoe in place and the tires loaded you should be good to go, go slow and keep us posted[
DevilDog/
/ Kubota 4240 ? #10
If the FEL will lift it, you've got it made. You may need to use a combination of lift and curl to get it started. That's why I mentioned securing it so it doesn't fall over. Can anyone grab some pics? Good luck!
/ Kubota 4240 ?
I will post pics of the operation when the safe comes in I have been waiting 13 weeks so far
/ Kubota 4240 ? #12
Remember that the rated lift capacity is to full height. Unless you are trying to lift the new safe more than a few feet off the ground, your lift capacity should be higher than "rated".
/ Kubota 4240 ? #13
It depends on how far out your load is but my thoughts are you should be safe! lol
/ Kubota 4240 ? #14
I think you'll just make it. Another option would be to use the loader to lift it from above with straps to get the weight closer to the tractor.
/ Kubota 4240 ? #15
Good point. You could actually remove the bucket/forks and just use straps or chain to carefully secure the load directly underneath the pivot point which would give you the best net lift capacity. Just don't leave much gap between the pivot point and the load as the geometry for lifting is best when the load is low.
/ Kubota 4240 ? #16
Fort Knox is a gun safe.
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2015 Kubota ZD1211RL 74in Zero Turn Mower (A64553)
2015 Kubota...
Cedar Swing (A65583)
2012 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A65643)
2012 TROXELL...
2017 INTERNATIONAL 4300 4X2 S/A 26FT NON CDL BOX TRUCK (A67147)
2017 INTERNATIONAL...
Landhonor Quick Attach Seeder (A66285)
Landhonor Quick...
