Kubota 3430
/ Kubota 3430 #1
wilson62
Bartow Fl
I believe kubotas 3430 puts out 8.3 gpm. Is there a way to get more gpm's out of this tractor other than pto pump? I need to get about 12 gpm's
/ Kubota 3430 #2
The PTO option is probally the easist and most economical. We are running one on the ChopZilla Hedging machine and it works great. The machine is amazing.
/ Kubota 3430 #3
That has to do with pump displacement, not just setting a valve differently like for pressure.
/ Kubota 3430
Well i wouldnt mind replacing the pump, but what pump do i replace it with? Is it aftermarket piece?
/ Kubota 3430 #7
That is the problem. The pumps are mounted directly to the engine and driven from gears, finding a larger pump that would bolt up would be next to impossible. Then you would need to know if the existing hoses/hardlines, and valves could take the extra flow...
There are no aftermarket solutions other than a PTO pump or a belt driven one of the engine-both would require another tank, filter, etc. Basically a seperate hydraulic system.
What are you trying to power?
