Kubota 3430
/ Kubota 3430 #1
wilson62
Bartow Fl
I believe kubotas 3430 puts out 8.3 gpm. Is there a way to get more gpm's out of this tractor other than pto pump? I need to get about 12 gpm's
/ Kubota 3430 #2
The PTO option is probally the easist and most economical. We are running one on the ChopZilla Hedging machine and it works great. The machine is amazing.
/ Kubota 3430 #3
That has to do with pump displacement, not just setting a valve differently like for pressure.
/ Kubota 3430
Well i wouldnt mind replacing the pump, but what pump do i replace it with? Is it aftermarket piece?
/ Kubota 3430 #7
That is the problem. The pumps are mounted directly to the engine and driven from gears, finding a larger pump that would bolt up would be next to impossible. Then you would need to know if the existing hoses/hardlines, and valves could take the extra flow...
There are no aftermarket solutions other than a PTO pump or a belt driven one of the engine-both would require another tank, filter, etc. Basically a seperate hydraulic system.
What are you trying to power?
1997 Fontaine FTW-5-8048WSAW 48Ft 34 Ton Flatbed Trailer (A64194)
1997 Fontaine...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2015 CATERPILLAR 730C OFF ROAD DUMP TRUCK (A65053)
2015 CATERPILLAR...
Swict 72in Bucket Skid Steer Attachment (A64553)
Swict 72in Bucket...
2019 John Deere 460E 46 Ton Articulated Dump Truck (A64194)
2019 John Deere...
2013 Caterpillar 420F 4x4 Extendahoe Loader Backhoe (A64194)
2013 Caterpillar...
