Buying Advice Kubota 2920
   / Kubota 2920 #11
Worklights front and rear, and the 40A alternator upgrade are all I can think of. And blockheater.
I didn't load my tires. My Land Pride 60" box blade is all the ballast I need for the fel or lifting logs.
   / Kubota 2920
I am not planing to do much heavy loader work and will use the blower if needed.
While I never had the tires loaded on the 1020. I don't know what to do with that. It is coming unloaded so I will try that and see if I have issues. I can always load them later.
I did most of the work on the 1020 and expect to do the work on this one also. the first service is at 50 hours. What is the service hours after that. I do like to be a little early on these things.
Tks for bringing up the alternator issue. I expect the it could be a issue as I do like to see where I am going. I was planing to put some LED lights on it when I know the dark areas. The LED's should help the load on the alternator but 14 amps is not much.
Where is a good placement of lighting on these units.
Al
   / Kubota 2920 #13
You will want the rear tires filled on the B2920 to counteract the weight of the front loader, otherwise it will be really loose in the tail. If primarily for mowing without the loader attached, then you can skip filling tires and plan on getting a ballast box that you attach when using the loader.
In general, I have found rear ballast is needed to offset the weight of the front loader for basic stability, then additional ballast to offset the weight of what's carried in the front loader. So plan accordingly. I always keep my loader on, so I have filled tires, and then I hitch up my box blade to offset weight of anything heavy I lift with the loader.
   / Kubota 2920
As I have never had a loader before I don't know if loaded tires will help if the loader is not used enough. Now that could change when I start using it and pushing the limits but I don't see that happening yet.
What would be a good counter balance on the 3 point hitch for this size unit. I will have the blower in the winter and could use it in the fall and spring but in the summer a easy rear weight would be nice if needed.
Al
   / Kubota 2920 #15
You definitely will want to get the rears loaded. Even without using much capacity on the loader you will have to be careful. Most dealers load the rears if there's a FEL. I actually have mine loaded and use a rear implement or the BH for weight when doing loader work (with just loaded rears you can lift them up with the loader easily). The loaded tires also do wonders for stability, the load is close to the ground and on the axle VS a weight box, which is good - but doesn't do as much for lowering the center of gravity. I believe loading is pretty cheap as well.
   / Kubota 2920
Loaded tires is something I will have to look into with the dealer. If the rears are loaded should they have tubes so the rims don't rust from the inside out or is tubes a automatic install when they are loaded.
I could be over thinking this installing tubes with loaded tires idea as they still use calcium/ water (I think) which would rust the rims out over time.
Al
   / Kubota 2920 #17
Hey Al, calcium chloride/water mix isn't the standard anymore. This is the stuff the dealer most likely uses:
Rim Guard - Liquid Tire Ballast
All four corners of my 2920 are tubeless.
If I were to use CC/water mix, it would only be inside a tube!
   / Kubota 2920 #18
Yup, no tubes needed. Rimguard won't rust the rims and I believe is a bit denser (heavier) than water. Should you somehow puncture a tire its non toxic and has good freeze tolerance.
   / Kubota 2920
Well I checked today with the dealer and I can have the tires loaded but the dealer said loaded tires and with the soft ground here it will mark the yard. The unloaded tires on the 1020 will put small marks in the spring. When he sells a FEL on a compact he includes the ballast box with it.
I will try the box and see if I like this idea if not loaded it will be.
Al
   / Kubota 2920 #20
That sounds like a good approach. Unloaded tires may work out for you. Try it! Report back.
2016 ROADTEC RP-190E ASPHALT PAVER (A52141)
2016 ROADTEC...
John Deere 1023E (A50120)
John Deere 1023E...
APPROX 21 SIDEWINDERS (A52472)
APPROX 21...
Bush Hog 84in Rotary Cutter (A50322)
Bush Hog 84in...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
