kubota 2007 B7800 4x4 tranny makes a loud winning noise when speeded up . hydro tra
   / kubota 2007 B7800 4x4 tranny makes a loud winning noise when speeded up . hydro tra #11
I'm a newbie, but why would one drive in 4 x 4 when just cruising down the road? Or does it really make any differance?
Well ..... you wouldn't (if you remember to shift it out of 4wd when you get to the road). The whine makes a good reminder.
   / kubota 2007 B7800 4x4 tranny makes a loud winning noise when speeded up . hydro tra #12
Four wheel drive on pavement leads to rapid tire wear through scrubbing.
On sand/dirt movement of sand/dirt acts as differential, so no scrubbing.
ALSO:
You need to engage 4-WD going downhill so you have four wheel braking.
If you do not have 4-WD engaged going downhill only rear wheels brake which, in freak circumstances, can lead to disaster.
   / kubota 2007 B7800 4x4 tranny makes a loud winning noise when speeded up . hydro tra #13
Thanks. It wasn't clear to me whether the OP was driving in 4 x 4, high gear on level ground. So running with the front drive in high gear could be the problem whine. But doing so is not a good idea for several reasons, including the whine. We'll see if the OP has diagnosed the problem, be it the relief valve (whatever/whererever that is) or otherwise.
I don,t drive in four wheel drive,, the tractor is a 4x4. sorry for the slip.
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2008 Kenworth T300 T/A Knuckleboom Crane Truck (A50323)
2008 Kenworth T300...
2007 PETERBILT PB335 LUBE TRUCK (A51243)
2007 PETERBILT...
2018 FREIGHTLINER CASCADIA (A50854)
2018 FREIGHTLINER...
2000 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A49461)
2000 Ingersoll...
2017 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNEL7HG551780 (A48836)
2017 Ram 5500 4x4...
