kubota 2007 B7800 4x4 tranny makes a loud winning noise when speeded up . hydro tra
   / kubota 2007 B7800 4x4 tranny makes a loud winning noise when speeded up . hydro tra #1
ohiojim
Member
going down the road .top speed the tranny wines loud ,back off and the noise stops . start going fast again it starts. sounds like a relief valve or something . question? easy fix?? how ?? . I.m handy and the kubota shop is booked two months out. noise sounds like its coming from mid tractor area. any help appre .
   / kubota 2007 B7800 4x4 tranny makes a loud winning noise when speeded up . hydro tra #2
Did it just start doing this after 6 years? If you just bought the tractor the HST in high gear at high speed has a normal whine especially noticeable on a paved road.
   / kubota 2007 B7800 4x4 tranny makes a loud winning noise when speeded up . hydro tra #3
All the tractors in this size that I have driven. Have a wine in H gear.
   / kubota 2007 B7800 4x4 tranny makes a loud winning noise when speeded up . hydro tra #4
That would have been my question as well. Did the noise just start? Has something changed recently? I have a B7510 and just after I purchased it I felt the same way about the noise from the machine in high gear. The dealer looked at and no issues found, but I was still concerned. Searched this site and most owners noticed same noise, turns out normal. Looked at a number of videos with the B7800, and listen to the tranny, and compare. Just my two cents,(well that is what I would say if we still had cents in Canada).
   / kubota 2007 B7800 4x4 tranny makes a loud winning noise when speeded up . hydro tra #5
My B7500 will do that if it is in 4wd, but the noise goes away in 2wd.
I suspect there is a slight difference between the front to rear gear ratios and the tire diameters.
   / kubota 2007 B7800 4x4 tranny makes a loud winning noise when speeded up . hydro tra #6
I specified Kubota SUDT2 at my 350 hour HST hydraulic fluid change. SUDT2 reduced high frequency wine more than half. Not total noise, just high frequency whine, which i found awfully annoying and gave me a headache.
Whine reduction seems to be mainly in HST transmissions, young and old, according to T-B-N posts.
this noise just started and its LOUD , not just a annoying whine, tractor even slows down , stop movement and start going again it dis appears but will come back if you speed up. tractor bought new no other problem, I still think its a relief valve not holding the proper presure,
   / kubota 2007 B7800 4x4 tranny makes a loud winning noise when speeded up . hydro tra #8
If you have a video camera can you record a start and stop cycle? It would help a lot to actually hear the noise come and go. I have a B2710 which is very similar to a B7800 and it whines like a teenager in high gear, but the noise steadily gets louder and softer with speed, there is no sharp increase in sound as you reach top speed.
   / kubota 2007 B7800 4x4 tranny makes a loud winning noise when speeded up . hydro tra #9
Scope out the plastic cover for the driveshaft going to the front axle ... try loosening the clamp that holds it and rotate it to a different orientation, then retighten the clamp.
Makes the loud noise on my B2910 magically disappear ... ;)
   / kubota 2007 B7800 4x4 tranny makes a loud winning noise when speeded up . hydro tra #10
I'm a newbie, but why would one drive in 4 x 4 when just cruising down the road? Or does it really make any differance?
2015 CATERPILLAR 272D2 WHEELED SKID STEER (A50458)
2015 CATERPILLAR...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
1994 Toyota 6000lbs 2 Stage Forklift (A52128)
1994 Toyota...
71065 (A49346)
71065 (A49346)
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
BUYERS PREMIUM & PAYMENT TERMS (A52141)
BUYERS PREMIUM &...
