Korean tractor dilemma
/ Korean tractor dilemma
A lot of new LS owners state they have oil leaks and you have to keep an eye out for loose bolts all the time.
But I get your point, spend up to 20% more up front for hopefully less headaches down the road.
This guy gets it
/ Korean tractor dilemma #22
The point is, it appears that korean built tractors are not built as well as kubota, deere, yanmar, massey. Seeing how i am 2 for 2 with them. Do i bite the bullet and spend the extra money up front for a so called name brand in hopes of having better results or do i try another korean built one and hope 3rd times a charm. I can tell you its not from how i am using them. I can also tell you that if you had been buying korean built tractors instead of kubotas , you wouldnt of had such good luck.
Well, three of those - Kubota, John Deere, and Yanmar - are mostly built in Japan and to Japanese manufacturing standards. I don't know about Massey anymore.
Whatever it is that the Japanese do differently, it does make them last longer and cost more. The same goes for a lot of their products, so their quality is no accident. I've had all three makes, and think that quality is worth the extra cost. Others see it differently.
rScotty - wishing I could say they were all built here.
/ Korean tractor dilemma #23
Im not stuck on loader lift but it is a big factor, same with ergo's i cant stand a loader mounted valve. The korean tractors do spec more and offer more per dollar, but at what cost? Reliability and parts support, is it worth it? Thats what i am trying to figure out
Loader lift on some models is a hugely misleading factor. I see higher lift capacities for some tractors in the company literature, but the tractor size and weight isn’t more than a comparable unit with lesser lift capacity. There are some brands that advertise higher loader lift than my tractor that weigh very close to mine. I have used mine at max lift capacity and can say that I wouldn’t trust trying to lift any more weight in this size tractor.
Massey is japan aswell. Its their culture, they have no life. Every thing is work work work and they have alot of pride. Koreans do alot of out sourcing, parts come from china vietnam ect. Plus they dont care as much. Remember when daewoo cars came to america? They were pure junk, same goes for kias and hyundais today.
So my ls 226 is comparable to the kubota l2502. My tractor weighs 3000lb with out loader or balast, loader is rated for 1900lb at 60in and 1500lb at full height of 94in. But the kioti ck2620 weighs around 2600-2700 lbs and is rated for the same as the ls lift wise. Being lighter you would think it would be rated for less. So i get what you are saying
/ Korean tractor dilemma #26
Why did you purchase a Korean tractor when you're already certain their manufacturing is subpar?
I could post links to threads of all brands having a list of common issues, many of which should have been caught by a good dealers PDI, but I'm not going to bother.
Go buy a Deere from a corporate dealer.
/ Korean tractor dilemma #27
To add to what tacticalturnip just posted….Seems like there’s a few complaints about the ck26 series loader mounts.
Kubota too . Point being, IMO, all the newer cuts and scuts have issues. Figuring out which ones have fewer seems to be luck of the draw nymore. Any chance you need some skid plating to work in the woods?
/ Korean tractor dilemma #28
Manufacturing post-COVID seems almost unpredictable, certainly from this outsider looking in's perspective.
I will say that you seldom see problems with Yanmar. I'd like to think that's not just due to their lower sales volume, but instead a positive display of their quality.
/ Korean tractor dilemma #29
No Cuts, Scuts or Putz here, never will be. I have no plausible use for a small tractor. Only 'putz' is me. If it's not at least 60 PTO power, it has no place here.
/ Korean tractor dilemma #31
That is your opinion.
My previous tractor was a John Deere 850 (built by Yanmar)
Was my John Deere a better built, more reliable tractor than my Kioti DK 35 I have owned the past 23+ years = NO
My Kioti has been great.
23 years and 2500+ hours, still working like new and it has never been back to the dealer
/ Korean tractor dilemma #32
Is it even possible to buy a Deere from an independent dealer? Are there any left?
Here in Maine I can only think of one off the top of my head; there may be more, but the vast majority are United Ag & Turf.
/ Korean tractor dilemma #33
One consideration about loader lift is 25hp tractors typically won’t be built to lift as much as 50hp mid size ones, but that throws you into DPF systems.
/ Korean tractor dilemma #34
I've been shopping for a (new or lightly used) 75-100 horse utility tractor and the only brand I could find that wasn't "globally sourced" was Kubota.
The Massey 4700 series isn't made in Japan and neither was the Yanmar SM475. I was told the Yanmar was just a rebranded TYM by the deal that I called. JD said their engines were made in the USA, but the rest of the tractor is globally sourced.
So just be sure to check where your specific model of tractor is made. Don't just look at the paint Color and think it's all good. Just because it's a Massey or a Yanmar does not automatically = made in Japan IME.
That might even been the case for Kubota too, I don't know. All the Kubotas I was looking at were made in Japan, but I don't know about their CUT or SCUT range.
Whatever you get, I hope you end up with a reliable tractor that you can trust!
/ Korean tractor dilemma #35
All Kubotas sold new in the U.S. are either Japanese made or a combination of Japan and U.S. sourced components.
/ Korean tractor dilemma #36
Thanks, that is good to know. I guess that makes Kubota the only brand who can make that claim.
/ Korean tractor dilemma #38
I think Yanmar can also make that claim. When you can find them.
I called a dealer about their SM475 (75 horse tractor for $54K). The guy I spoke to told me it was just a rebranded TYM, not a real Yanmar.
/ Korean tractor dilemma #39
That's new, part of a recent partnership between the two. That SM is the first model I've seen made by TYM.
/ Korean tractor dilemma #40
Specifically made in (assembled) in Georgia. The big ones still ship in containers from Japan (and Italy) and the little ones are made here with, I believe crated engines made in Japan.
Any time I see the blurb 'globally sourced components', I cringe.
Kind of like the blurb 'World Class Manufacturing'.... To me that equates to anywhere it's cheaper.
2014 Dodge Caravan Van (A64557)
2014 Dodge Caravan...
2023 Mercury Verado 350HP Outboard Boat Motor (A64557)
2023 Mercury...
LOAD OUT AND SHIPPING (A65583)
LOAD OUT AND...
2007 Peterbilt 379 T/A Kill Truck (A64194)
2007 Peterbilt 379...
New/Unused Landhonor Hydraulic Quick Attach Auger (A65583)
New/Unused...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
