Knife & a Half
/ Knife & a Half #1
Ghost River Retrievers
Benton County, MS
New Holland
I know that sickle mowers are largely out of favor these days, but my 9' NH451 is my favorite tractor implement. It's a huge time-saver when cutting around my 6 acre lake, which has steep banks in some parts, especially along the dam. I also use it to cut strips in the weeds/hay (that's related to my retriever training hobby).
It has always worked great for the lake, but when cutting the weeds/hay, it would get clogged up pretty badly at the end.
A couple weeks ago I found a few discussions about sickle mowers and clogging, with one article mentioning a "knife and a half." I'd never heard of such a thing (and it's not mentioned in the Operator's Manual or Parts Manual), but did a quick search and found a set at TSC.
I put it on the cutter bar and it was life-changing (that's only a slight exaggeration). To cut for over an hour without having to get out of the seat to clear a clog is HUGE!
I'm looking forward to this evening's sickling.
GRR
/ Knife & a Half #2
Thanks, sounds like exactly what I need.
But searching on TSC provides no hits. Pocket knives aplenty. Sickle mower provides no hits, either.
Any chance you can provide a link? Thanks.
/ Knife & a Half
Here you go:
I don't have a way to rivet the third hole, so I left it empty ... which is exactly what the discussions I found the other day said to do. It works fine that way ... at least it's worked fine for the 2 - 3 hours that I've sickled since putting it on.
Good luck!
GRR
/ Knife & a Half #5
I love using my 451 as well, I will never get a rotary mower.
/ Knife & a Half #6
So you put the knife and a half only at the end of the bar?
/ Knife & a Half #7
Do they work with haybines? If they do, wish I’d known about them when I was running my 1499.
Wolverine Quick Attach Tiller (A66285)
Wolverine Quick...
2007 MACK GRANITE CTP713B DUMP TRUCK (A64280)
2007 MACK GRANITE...
Steiner 450 (A64126)
Dodge Charger (A64557)
2013 KENWORTH T370 DUMP TRUCK (A65054)
2013 KENWORTH T370...
John Deere 2210 Field Cultivator 43' (A63688)
John Deere 2210...
