KL120 Loader Flexing
Status
Not open for further replies.
   / KL120 Loader Flexing #61
Just went out to the garage, mine does NOT have the bracing TPDonnely has.
I thought I read previously that his came from the dealer that way, maybe the dealer installed it?
Tom
   / KL120 Loader Flexing #62
Excelent race report.
I never did an enduro but only 11 minutes back sounds like a big trophy. You'll have to do the loader deflection test by putting your trophy on one side of the bucket checking the sag.
I don't think most people know that formula:
Wet tree root on 45* angle + your front tire = faceplant
Now back to our regular scheduled programing.
Thanks, Larry
   / KL120 Loader Flexing #63
Oh yes, a 45 degree horizontal angle 6inch root just underwater in the mud puddle = laying sideways in the puddle because you didn't antipate the rapid drop in elevation and no time to put a foot down.
11 minutes at the last check, meaning the previous couple of checks were 5 and then 8 so the points were adding up. I was pushing and wasn't getting passed so not sure how everyone else did.
The loader improvement, if done by Kioti, shows a resolved defect. I hope, I hope, I hope this is a Kioti thing. Any dealers on the board to look at a new machine in their yard?
   / KL120 Loader Flexing #64
I feel we can be assured that the dealer did not add the bracing to the loader. I'm sure that Kioti had had this problem show up, and had the loader fabricator correct it with better bracing. Then they would deal with loaders of the same problem on a piece by piece basis, hoping that warranties would be out by the time it showed up. Any company would probably proceed this way.
I'm sure you should have a new loader, or at least the frontal parts that experienced the problem.
John
   / KL120 Loader Flexing #65
I expect product evolution in response to field discovered weaknesses. Every year the auto makers come up with a new and improved version in response to market demands.
It actually gives me some confidence that Kioti is on the ball. Could someone with a spankin new loader, or at least pretty dang new, check to see if they have this new reinforcement from Kioti? I'm trying to get a timeline of the improvement. There's a fine line between product improvement/evolution, as needed replacement, and recall.
Is there some reason you dealers are being awfully quiet here or am I just anxious and not very patient? Is mum the word? Maybe I'm just anxious.
Let me make a new thread since maybe dealers aren't excited about reading about loader flexing.
   / KL120 Loader Flexing #66
</font><font color="blue" class="small">( I'm sure that Kioti had had this problem show up, and had the loader fabricator correct it with better bracing. Then they would deal with loaders of the same problem on a piece by piece basis, hoping that warranties would be out by the time it showed up.
)</font>
I'm not so sure about that. I think that a larger company might issue a recall.
I know I had a recall on one of my loaders (to prevent brand wars I will leave the brand name out but PM me if you want to know the brand and model of the loader). It was based on an issue that "may occur" on "some" loaders. I wish I still had the notice. Turns out mine was one that could have had the problem. All it was was a simple hydraulic fitting. Some loaders had a low profile unit installed and others had a high profile unit. But all the owners of the loaders were apparently contacted because the manufacturer didn't know which had which. It was a simple visual inspection that could be done by the owner. If you had the "wrong" fitting, the dealer showed up, picked up the tractor, replaced the fitting and returned it to you.
Personally I think it says something about the company that they took a proactive stance and issued the alert to all owners of the loader. They obviously didn't want a loader out in the market that would fail to perform as expected. I'd rather they fix all the defective ones rather than just wait to see who complains and fix only those.
Further, to get out of fixing something in hopes that the warrenty would expire before the owner notices the problem is somewhat questionable in the ethics department. JMHO
   / KL120 Loader Flexing #67
The automotive business handles this with a Technical Service Bulletin where if you come in to the dealer with a particular problem then they replace the part with the improved version for free. Recalls are generally only forced with safety issues but it would be a great PR move here.
There is more to this new loader than meets the eye. We are about to see whether or not Kioti has what it takes to survive. We are about to see if they do the right thing.
   / KL120 Loader Flexing #68
</font><font color="blue" class="small">( I'm not so sure about that. I think that a larger company might issue a recall. )</font>
Bob, not to be argumentative, but I have to say that you are very likely not aware of what went on with that issue before you ever heard anything from the company. Threats of lawsuits over that issue may have precipitated the recall.
We have had in this country many instances where companies had to be forced into recalls, one example, outside gas tanks on pickup trucks that exploded in accidents. That was certainly a BIG company. There are many others. Companies seem to rarely offer a recall unless there is someone, some organization, that pushes them into it.
I think it is naive to believe in this day and age that any company is going to call out a problem and fix it unless they clearly see that it is ultimately going to cost them more in the long run if they don't.
In the case of your loader, the valve could have led to a terrible hydraulic pressure accident that would have likely let to lawsuits costing in the millions, probably much more than just a recall would have cost.
John
   / KL120 Loader Flexing #69
John, I never said I knew the background. And no doubt a high pressure hydaulic failure could result in a potential lawsuit (but given the contained location of this fitting I doubt that anyone would have been squirted if the fitting cracked. . . it is more likely the loader would leak down and fail to function).
But lets take a look at Highbeam's loader. If that cracks through while in use, it would be a catastrophic failure that could lead to injury or death of the operator or someone nearby. Different problem similar outcome = lawsuit!
But the companies certainly are handling it differently.
Heck just from the liability standpoint I'd think that it would be nuts for any manufacturer to approve of a repair job by a dealer that altered the structural members of a loader. Not being brand specific here. Just observing and commenting.
But I'd think a liability lawyer would be able to have a field day if ANY BRAND of loader was repaired that way and it gave way. First the lawyer would go after the manufacturer for not recalling a loader that had stress cracks. Then they'd go after the repair shop for "engineering" a fix without consulting real engineers!
John wrote: <font color="blue"> Then they would deal with loaders of the same problem on a piece by piece basis, hoping that warranties would be out by the time it showed up. Any company would probably proceed this way. </font>
Further, they woud very likely make a really big deal about the fact that the company was aware of the problem and wanted to let people's warrenties expires instead of fixing them under warrenty or via a recall. Not the best business practices for a company that wants to develop a good reputation. And that would also probably be grounds for a class action suit by people who owned the loaders.
   / KL120 Loader Flexing #70
</font><font color="blue" class="small">( John, I never said I knew the background. )</font>
No, you didn't. But what you DID say is that a bigger company might issue a recall because your's did. You don't know why they did, but you make it out as though that company was doing something out of the goodness of their hearts, or for good PR or whatever reason, but you can bet it was to save money in the long run.
What we know of Joe's situation tells me that Kioti wasn't included a whole lot in this fix, and we have yet to hear anything about discussions with Kioti rather than just with the dealer.
For all we know, the company to which you refer was forced into a recall and letting each owner know about the defect. Unless we know those circumstances, your points are moot.
John
Status
1459 (A57192)
1459 (A57192)
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
Kubota M108S (A53317)
2757 (A55787)
2757 (A55787)
1998 Homemade S/A 12x6.5ft Trailer (A56859)
1998 Homemade S/A...
SHOP BUILT TOOL TRAILER (A58214)
SHOP BUILT TOOL...
