KL 130 REMOVAL
/ KL 130 REMOVAL #1
Leithal
Lacey's Spring, Alabama
RK 24
Hi, Y'all,
I'm, having a slight issue removing my loader, I can't get the rear two quick disconnects to come loose. ( aft looking forward,the ones most rear of the tractor ) The front one came loose fine. The collar will slide back but it won't disconnect.
/ KL 130 REMOVAL #2
I take it you are talking about remote hyd hoses ? Do you have all the hyd pressure removed ?
/ KL 130 REMOVAL #3
sometimes you need to shut down the tractor and move the loader stick in a complete circle to relieve all the pressure in the loader hoses then the collar should move. If its rusted spray some penetrate on it then tap on it lightly with a hammer and it should loosen up.
/ KL 130 REMOVAL
Yes, remotes hoses, tractor off, moved jou stick around several times. Tried again 2 hrs later, no joy. Red and blue disconnected, yellow and white still stuck, collar will rotate and slide back but won't uncoupple.
/ KL 130 REMOVAL #5
Sounds like one or multiple balls are stuck can you rotate the entire coupler with the collar pulled back? You might have to resort to removing the hoses and then removing the couplers from the tractor. Once you get them on the bench you can soak them and try to get them free'd up. Discount hyd on line has replacements here is the number.
600-06-06S | 3/8" Hydraulic Quick Disconnects (Steel)
/ KL 130 REMOVAL
Yep that was it, had some stuck balls, just had to lube it up real good, wrapped it with a rag and tapped it a few time with a dead blow. Then moved it around a bit and they finally popped loose. Had a little bit of surface rust on the male side of the coupling. Uses some scotch bright and some WD-40. Good as new. Sorry i didn't update this earlier but been outside all day trying to get some stuff done before the storm move in. Appreciate all the replies and advice. Y'all have a good one.
T/A Drop Deck Equipment Tailer (A64556)
T/A Drop Deck...
2015 Bandit 200UC Chipper (A63689)
2015 Bandit 200UC...
MASSEY FERGUSON 1838 IN-LINE SQUARE HAY BALER (A64277)
MASSEY FERGUSON...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
Freightliner Columbia (A63689)
Freightliner...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
