Bob_Young
Veteran Member
- Joined
- Jul 5, 2002
- Messages
- 1,244
- Location
- North of the Fingerlakes - NY
- Tractor
- Ford 4000; Ford 2000(both 3cyl.);JD40; 2004 Kubota L4300; 2006 Kubota B7610; new 2007 Kubota MX5000
Hi,
The Northern Tool Catalog lists an XB Carryall frame that's sized for SubCut tractors. Looks like it would work well for carrying firewood on my B7610 if I built a wooden bed on it.
However, the catalog states it is compatible with Cat 0 3 pt. hitch...as are the rest of the XB implements listed. Of course the B7610 is Cat 1 as is the BX series (which I thought the XB line was designed for). Will I need to replace the Cat 0 pins with Cat 1 and drill out the toplink hole, or do I stay with Cat 0 and use bushings? I don't recall seeing Cat 0 to Cat 1 bushings at TSC.
Is anyone using XB implements on a B-series Kubota or other Cat 1 CUT? Do they fit OK or are they strictly for smaller tractors? I like the looks of their 4' XB brush cutter and their XB tiller.
Thanks.
Bob
Thanks.
Bob
