Mowing KK Finish Mower
/ KK Finish Mower #1
Bart
The PTO shaft on my new KK finish mower is veryhard to turn by hand. The old Bush Hog finish mower I had used previously would turn very easily and the blades would spin.Curious if this could be causing the grinding sound
/ KK Finish Mower #2
I'd be very weary of any grinding sounds from the gearbox!
/ KK Finish Mower
Sorry !!! The grinding noise is cominf from tractor PTO when I engage it
/ KK Finish Mower #4
Hmmm. That dosen't sound good either! /w3tcompact/icons/frown.gif Different cutters will "act differently" but none should be really difficult to turn by hand. /w3tcompact/icons/frown.gif
/ KK Finish Mower #5
i had a kk finish mower before i got the befco, it turned by hand, difficult ,but it turned. i pulled it behind an old ford 2n and it never gave that any trouble, no grinding or such.do u have any other 3 pt. driven implements? and if so do they make the tractor give the same sound?
/ KK Finish Mower
Frank, Ionly have a 6ft HD Woods bushog for m my John Deere and that is at my farm 200 miles away.That PTO as far as I can remember also turns by hand not easy but it turns
Maybe I'll ask the dealer Ibought it from
/ KK Finish Mower #7
Bart,
I have a 6' kk finish mower, and it is very hard to turn the pto shaft by hand. My 5' brush hog is fairly easy to turn. I believe the difference is due to the pullys and the tension of the belt. Since my NH 35D pto shaft does not freely turn, I am forced to turn the shaft on the implement when connecting to the tractor. As I said, this is a bit difficult with my mower, but since I operate the mower without the belt guard in place, I am able to turn the shaft by pulling on the belt, which rotates the shaft. It's a bit awkward to do while trying to hold the shaft collar to the tractor pto shaft, but it works. Hope this helps. Good luck.
/ KK Finish Mower #8
I have a 5' KK finish mower I bought last year. I can't turn it by hand either. Have you checked the PTO shaft to see if it is the correct length?
/ KK Finish Mower #9
My 6' KK finish is hard to turn too. Due to the pulleys and three blades. My 5' KK rotary is easy to turn. That's all normal.....but that grinding you are talking about I would have looked at!
/ KK Finish Mower #10
I don't know about the "grinding" noise; that would probably concern me, but as for turning the driveshaft to the mower . . . I don't know about others, but I could turn the driveshaft easily by hand on my Bush Hog tiller and Howse rotary cutter, but NOT on the RDTH60 Bush Hog finish mower. When I wanted to turn it by hand (to grease the u-joints), I had to put a metal bar through a u-joint to turn it. I just attributed that (whether right or wrong) to the fact that it had one belt winding around the pulley on the output shaft of the gearbox AND three blade spindle pulleys. But when I engaged the PTO, the tractor never had any problem at all spinning it.
/ KK Finish Mower #11
Any chance you could get the mower on someone else's tractor and see how it sounded? My Woods mower is very difficult to turn by hand, especially since I rebuilt the bearing housings. Even when it somewhat easier I could never spin the blades however, more like just get them to turn. With my new NH TC40D I now have a lot of trouble hooking the PTO up, fortuneately the mower has a big flywheel that I can turn in order to get the PTO shaft and coupler aligned. Never heard any grinding though.
/ KK Finish Mower #12
My BEFCO turns by hand with almost no effort.
/ KK Finish Mower #13
I just bought and put together a new 5' KK finish mower. The PTO shaft is very difficult to turn because of the spindle ratio's used to obtain the high blade speeds. I hope you noticed that the KK comes ungreased with no oil in the gear box. The blade spindles take a lot of grease. I used almost a hole tube before all fittings were filled.
/ KK Finish Mower #14
My KK 72" finishing mower is also difficult to turn by hand. As a matter of fact, I think every time I have ever turned it, I either did it by pulling the belt or the blade. Mine also took a whole tube of grease to get everything lubed up!
Steve
(3) Pieces of Poly Pipe (A62679)
(3) Pieces of Poly...
New/Unused Wolverine Mini Quick Attach Pallet Forks (A65583)
New/Unused...
2014 MACK PINNACLE DAYCAB (A59914)
2014 MACK PINNACLE...
2019 HYDREMA MX18 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX18...
2019 HINO 195 18FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 HINO 195 18FT...
2021 CAT 299D3xe Skid Steer w/ 2021 CAT HN415c Mulching Head (A62613)
2021 CAT 299D3xe...
