Kit outbuildings for your vehicle storage
   / Kit outbuildings for your vehicle storage #11
That is how we started out, sold the RV and after adding metal to the sides we now have enclosed parking for the tractors and the generator is now out of the way of the car and trucks.
   / Kit outbuildings for your vehicle storage #12
There’s gonna be nothing Low Cost about a 30x40 fully enclosed building with doors. I looked at the Versatube Standard Kit 30x42 and it was $19,600. And I doubt that was with doors. I just had a 30x40 lean-to built locally with 3 sides. 14ga square tubing, I-beams, and 24ga Galvalume for $14,000. I looked and looked for the best building with best price. Wood structures are now more expensive than steel. It was a tough decision on what I was gonna do. I’d LOVE to have a 30x40 fully enclosed with a concrete slab, but this is all I could afford right now. And I’m not complaining. It’s just the steel and wood market are Crazy right now. Absolutely Crazy, I tell ya! ! ! Oh yeah, and your gonna fill that thing up Muy Pronto with a tractor, atv, motor home, and boat.
A majority of RV ports are 20'x40'x12' in WxLxH dimensions, and are made of metal. Typically are custom ordered for customers specific color choice. You could place two such RV Ports in close proximity, and achieve 40'x40'x12' of covered parking. Projected Costs should range upto $4800 installed for each, or $9600 total. If you really have a bigger budget, you can then bring in gravel base for parking vehicles on, and do solar powered lighting around the structures for night lighting.
thats a good idea. I'd do a gravel base for sure. I'll have to see what the excavation runs to see how i can finish it off. Thanks.
i hear you. Materials are getting crazy. I should have done this a couple of years ago, but I just decided to get a new tractor and am finally running out of room in the shed and garage!
   / Kit outbuildings for your vehicle storage #15
Back in 2018, I got a steel pole barn 30x40x14 with a 4inch concrete slab done for $25k. Similar rebuild is now touching $40k :(
   / Kit outbuildings for your vehicle storage #16
My wife and I built a 14 x 27 VersaTube for a tractor that worked okay for a few years until I replaced the tractor with on that didn’t stand a chance. I believe cost was well under $5k but darn there were a lot of self-drilling screws to install. Structurally it was strong but sealing is difficult as the roof forms lateral water holding channels. We replaced it with a much larger, sturdier, and super costlier pole building whatever we build it’s not enough.
   / Kit outbuildings for your vehicle storage #17
My primary concern here is rodents, which do more significant damage to wiring and tubes (like my diesel fuel return line) more rapidly than weather does. I personally wouldn't build a structure that's not reasonably rodent-secure.
   / Kit outbuildings for your vehicle storage #18
A building needs to be pretty much air tight to be "rodent-secure". If you can see light under a door, they can get in. I'm quite certain the pesky creatures can shape-shift at will. :sneaky:
   / Kit outbuildings for your vehicle storage #19
I had a 21 ft x 18 ft boxed eave carport installed for $2500. Big enough for my tractor, implement and side by side.
I would recommend to look at local metal buildings installers. The concrete pad will probably be just as expensive as your building.
   / Kit outbuildings for your vehicle storage #20
I found that out in the country cats work well for small rodents. I've only got two cats but I've seen them by the carport shed where I park the tractor. Never seen any damage to my tractor or side by side from rodents.
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2000 Mack CH13 (A56435)
2000 Mack CH13...
New/Unused Mini Crawler Dump (A57453)
New/Unused Mini...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
