kioti NX4510
/ kioti NX4510 #1
stuart50
columbia ms
135 massey feguson
NX4510 2016 tractor cranks right up idles fine then the gauges go to fluctuating and its like you shut off then catches right back up may run a hour then throws another fit is this possibly electrical failure?
/ kioti NX4510
Still having problems with Nx4510 feels like a miss almost dies when gauges sweep then runs decent at idle but goes crazy again when throttling up
/ kioti NX4510 #3
I would check the battery, most importantly the battery terminals being clean, move on to the ground connections. also make sure your alternator connections are good. Sounds to me like you have the computer messing with the tractor, and most cases that is a connection issue and/or a battery failure, basically a voltage issue.
/ kioti NX4510
Ok I’ve had my tractor at the dealer only code it is showing is for a engine exhaust temperature sensor being bad and of course they don’t have one and could be up to 3 weeks getting one does anyone have a cross reference that might work I know it is K rated sensor any help would be great still don’t know if that will fix the problem with the miss or gauge sweep but this needs fixing so it will regen properly sorry for the long post
1667 (A57192)
1667 (A57192)
Abaco Machines DVL500 Vacuum Lifter (A59230)
Abaco Machines...
2011 Toro Multi Pro 1250 Gas Sprayer Cart (A59228)
2011 Toro Multi...
Kubota L4701 (A53317)
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2018 Chevrolet Traverse SUV (A60352)
2018 Chevrolet...
