Kioti lk2554
   / Kioti lk2554
The new pump worked ok not great for about 5 minutes
   / Kioti lk2554
Yes I cleaned the two valves. Yes that Allen head plug is we’re Kioti finally told me to test from there
   / Kioti lk2554 #13
I wonder if you have a supply problem. I am guessing you changed filter? If the pump is not pumping some where around 7 GPM and it is new either the pump is not turning and there is a problem with the drive gear or a blockage somewhere on the suction side.
   / Kioti lk2554
No one around here can bench test the pump. I did pull off the supply hose going to the loader for the flow test. T2567-76041 I have found this pump it’s like 2000. I paid 3000 for the tracker from a man down sizing
   / Kioti lk2554
Yes filters are all new. I have no bubbles no foam coming back into the transmission indicating sucking air. All the cylinders on the louder have been repacked
   / Kioti lk2554
Has anybody found a place to rebuild this?
   / Kioti lk2554 #17
You definitely have something going on but I do not think it is the pump. How did the old one go out? Did it gradually get weaker over time or did it stop work all at once?
   / Kioti lk2554 #18
I might have the gear drive that bolts to the injector pump. I will look and see if I can help.
   / Kioti lk2554
When I got it it had a flat. The older guy lifter the front end with the loader that was the last time it ever could do that
   / Kioti lk2554 #20
Ok based off of that information I think you have a drive gear issue. Your old pump is probably ok so don’t throw it away. Lol
2011 Ford Transit Connect Cargo Van (A50323)
2011 Ford Transit...
NEVER USED FECON 74in Deck Mulcher FDM74 (A52748)
NEVER USED FECON...
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
2015 Ford F-550 XL (A50120)
2015 Ford F-550 XL...
P.T 1000 Gallon Supply Tank (A50120)
P.T 1000 Gallon...
66in Light Material Bucket Skid Steer Connection (A52748)
66in Light...
