Kioti lk2554
   / Kioti lk2554 #1
Michael little rock
Kioti lk2554
I have a problem with hydraulic pressure. I want to test the psi of the pump at the Auxiliary block on the Sid of the transmission. I need to rule out the pump or the Block itself. Is there a test port in that block?
   / Kioti lk2554 #2
I am not aware of a way to test pressure in the block itself. What issues are you experiencing?
Your block is missing the valve that changes flow to feed the loader. It has a plug where that is on mine. Yours must be a newer model than mine.
   / Kioti lk2554
Thanks I had to call a big dealer then the one by me for help. They had to look it up. There is a port to check the pressure. I’m only getting 200-300 psi. There is no one that I can find that rebuilds these pump. Thank for your help
   / Kioti lk2554 #4
I replaced my pump several years ago. They made a upgrade pump that is 10 GPM. This was for the LK 3054 but I put it on my 2554 with no issues. It was a huge improvement over the 7 GPM one. I made a thread about it if you would like to read. Good luck.
   / Kioti lk2554
K5
Yes I read your post. I can’t remember why I didn’t do it. It could have been finding the pump. The one I put on it is pumping 200-300 hundred. The test port was 1/4 tapered British threads. What a pain finding that in town. The book tells you it’s 3/8. That’s not the only mistake in the book. Thanks
   / Kioti lk2554 #6
So I guess now this has been a ongoing problem. Did you check the flow rate of the pumps?
   / Kioti lk2554
Yes molasses drips out of the bottle faster. The place I got the pump from is saying my fault it went out. Here we go. Did you buy a used one. Was it tested before you got it.
   / Kioti lk2554 #8
If the line with the yellow arrow comes from the output side of the pump, then the plug on the red circle should be a test port to get readings straight from the pump.
Hard to be 100% sure without a schematic.
   / Kioti lk2554 #9
Those lines feed the power steering. There have been a few guys need to take the priority valve apart and clean. That solved their problem on pressure but it sounds like something else in this case.
   / Kioti lk2554 #10
So if I understand correctly, you replace the pump for the same reason and it worked for some period of time? Now it is doing the same thing?
1996 Elgin Pelican Series S Street Sweeper (A50322)
1996 Elgin Pelican...
Unused 2025 CFG H15 Mini Excavator (A50322)
Unused 2025 CFG...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
John Deere 51" Sweeper (A50774)
John Deere 51"...
Frontier AB13D Hay Spear (A50120)
Frontier AB13D Hay...
2010 Toro Z Master 2000 52in. Zero Turn Commercial Mower (A50322)
2010 Toro Z Master...
