Kioti LB2204 hydraulic issues
   / Kioti LB2204 hydraulic issues #42
Yes, you need the PB sleeve for that valve. Ptsg is correct.
   / Kioti LB2204 hydraulic issues #44
Yours is a priority valve that has a diverter to enable changing flow. It is for your power steering. It makes sure there is always flow for the power steering. The diverter part only changes what is left after power steering to the port that feeds your loader or 3 point.
When I install new hoses do I need to let hydraulic fluid flow with the hose off to get air out or is that not necessary?
   / Kioti LB2204 hydraulic issues #46
It should self Purge the air out. You will need to work the cylinders fully in each direction to get all the air out of the system.
Thank you, this weekend I’ll be getting new hoses and the new loader valve installed.. will keep you posted as to how it works
Could a wrong hydraulic filter installed be restricting my flow?
   / Kioti LB2204 hydraulic issues #49
It is possible. What are you seeing?
I was just thinking maybe that it had the wrong filter on it and I then replaced it with a similar incompatible filter and that’s the cause for low flow test. But would that similarly cause the lack of pressure?
John Deere 7430 (A50120)
John Deere 7430...
Kubota BX2230D (A47384)
Kubota BX2230D...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2016 Ford Escape SE AWD SUV (A50324)
2016 Ford Escape...
John Deere 6100D (A50120)
John Deere 6100D...
