Backhoe Kioti KB2475 backhoe teeth
/ Kioti KB2475 backhoe teeth #11
UPDATE:
PATCHES - I checked with local Kioti dealer (parts) and was told the part #'s you provided me will not work for my application (DARN!)
Before you do anything, I would check with Michigan Iron & Equipment. When I ordered my 9 inch bucket, the dealer(not MIE) told me it was the same bucket through the CK series tractor line also? They may have changed manufacturers, but I would be surprised if the #'s I provided would not work
COLEMAN EQUIP ... This is a really good site. I am learning a lot from them. Thank you - Frosty
UPDATE:
Thank you Patches - I will check with them. Appreciate the info - Frosty
/ Kioti KB2475 backhoe teeth #14
Romacparts.com is where i by all of my teeth and I'm pretty sure I bought the same teeth as yours from there. It's a big site but you will find it.
/ Kioti KB2475 backhoe teeth #15
OKAY! Here is the FINAL END result ... I knocked (i.e. cut w/ torch) a tooth and took it to a local CASE dealer. The parts counter gal selected a scarifier tooth that 'might' fit. The shank measures 1 1/8" w and the inside of the tooth was the same. It would not quite fit onto the shank. I decided the difference being between metric and standard measurements - so ... grabbed the grinder and to a mm (or two) off of the shanks, knocked the new teeth on, heated and dimpled 'em best I could and added a little weld to top front and back. Can't remember when it dug so good (YAY)!
Romac blew me off and Michigan Machine phoned and said they found some ($28 ea + shipping). I paid $27 for the three I got from CASE. Also - FYI - I found on the Kioti teeth < TAE SUNG >. They are a Korean drill manufacturing company - mostly diamond drills for petroleum industry. My guess is they manufacture the buckets for Kioti on the side. Hope this info will help others. Frosty
/ Kioti KB2475 backhoe teeth #17
H&L 00 Weld on/ crimp bucket teeth, Ordered 4 teeth and got them in 2 days.
HERE
2019 CATERPILLAR 305.5E2 CR EXCAVATOR (A62129)
2019 CATERPILLAR...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
2005 SHOP MADE MANIFOLD TRAILER (A60736)
2005 SHOP MADE...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
Kubota BX25D (A53317)
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
