Backhoe Kioti KB2475 backhoe teeth
/ Kioti KB2475 backhoe teeth #1
Frosty
SW Idaho
Kioti CK35 HST; Kubota KX040
I need to replace the teeth on this backhoe. The owner's manual shows no separate part number for the teeth and the dealer does not list them either. Seems you have to replace the entire bucket - YIKES! Has anyone replaced the teeth on one of these? I have a 12" bucket w/ 3 teeth.
/ Kioti KB2475 backhoe teeth #2
You shouldn't have to replace the bucket.... Do you have the broken off teeth? Can you post pics of the bucket/teeth, etc? How'd they all get broken off? You might be able to get them or new ones welded back on with a bucket repair by a good welder- depends on the extent of the damage. Teeth are available, though possibly not through Kioti; but teeth are made for replacement on other similar equipment....
They aren't broken off, just very well worn from digging in gravel we have here. I have added weld to them on the ends a couple of times and figure it's time to replace them. They have "dimples" on them where I think they slip onto the 'welded tooth anchors' that they would clip onto ...? I am thinking that if I have to replace the bucket I could replace it with CAT or JOHN DEERE, something with 'replaceable' teeth. I don't know if the pins would match though, haven't checked into that.
I have attached pics
/ Kioti KB2475 backhoe teeth #5
The teeth look replaceable to me.
They look the same as the teeth on my Rhino backhoe.
You should be able to just knock the tooth off with a hammer, replace the tooth and peen the tooth recess into the shank.
That's kind of what I thought, but I haven't found any 'replacement' teeth ... I have not tried to knock them off.
/ Kioti KB2475 backhoe teeth #7
What DK35vince said: look at Rhino hoe replacement teeth to start. Or try Googling tractor backhoe replacement bucket teeth, or similar....
/ Kioti KB2475 backhoe teeth #8
I have an '04, 3054xs with the KB2376 hoe with both a 9 and 18 inch bucket; both have replaceable shanks and teeth. My hoe manual shows the Kioti part number to be BH20-0110 for the shank and BH20-0111 for the teeth
UPDATE:
Well .... okay, I've searched for the teeth and haven't come up with any - that have a pic so I can be reasonably assured they would work. The backhoe is off the tractor right now so I'm not able to 'mess' with the teeth.
PATCHES - I checked with local Kioti dealer (parts) and was told the part #'s you provided me will not work for my application (DARN!)
I phoned Kioti Hdqtrs in N.C. and was told yesterday that these teeth are not replaceable. After looking at the Kioti backhoe website it clearly states as STANDARD features: All buckets have replaceable teeth. I phone N.C. again today and was told that "Yes, the teeth are replaceable." However, Kioti does not carry replacement teeth, that I should be able to find them on Northern Tool, Tractor Supply or similiar sites. They are considered replaceable because they are welded on the buckets and can be cut off and new ones welded on. OH WOW! How convenient. Thank everyone for their input and ideas, much appreciated. Frosty
/ Kioti KB2475 backhoe teeth #11
UPDATE:
Before you do anything, I would check with Michigan Iron & Equipment. When I ordered my 9 inch bucket, the dealer(not MIE) told me it was the same bucket through the CK series tractor line also? They may have changed manufacturers, but I would be surprised if the #'s I provided would not work
COLEMAN EQUIP ... This is a really good site. I am learning a lot from them. Thank you - Frosty
UPDATE:
Thank you Patches - I will check with them. Appreciate the info - Frosty
/ Kioti KB2475 backhoe teeth #14
Romacparts.com is where i by all of my teeth and I'm pretty sure I bought the same teeth as yours from there. It's a big site but you will find it.
/ Kioti KB2475 backhoe teeth #15
OKAY! Here is the FINAL END result ... I knocked (i.e. cut w/ torch) a tooth and took it to a local CASE dealer. The parts counter gal selected a scarifier tooth that 'might' fit. The shank measures 1 1/8" w and the inside of the tooth was the same. It would not quite fit onto the shank. I decided the difference being between metric and standard measurements - so ... grabbed the grinder and to a mm (or two) off of the shanks, knocked the new teeth on, heated and dimpled 'em best I could and added a little weld to top front and back. Can't remember when it dug so good (YAY)!
Romac blew me off and Michigan Machine phoned and said they found some ($28 ea + shipping). I paid $27 for the three I got from CASE. Also - FYI - I found on the Kioti teeth < TAE SUNG >. They are a Korean drill manufacturing company - mostly diamond drills for petroleum industry. My guess is they manufacture the buckets for Kioti on the side. Hope this info will help others. Frosty
/ Kioti KB2475 backhoe teeth #17
H&L 00 Weld on/ crimp bucket teeth, Ordered 4 teeth and got them in 2 days.
HERE
100" Bucket (A64119)
Unverferth 6225 (A64119)
Unverferth 6225...
UNUSED IRANCH IRGC40 HIGH END MINI GOLF CART (A64281)
UNUSED IRANCH...
2002 International 9200i Truck (A61307)
2002 International...
(2) UNUSED 320/85R24 TIRES (A64280)
(2) UNUSED...
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
