Kioti K9 Parts
   / Kioti K9 Parts
Thank you for your response. I think it has the same diesel as the ck26
   / Kioti K9 Parts #5
Do you have the numbers from the original filter?
   / Kioti K9 Parts
Just used you Wix link and am going to give Wix 51381 a try.
P.S. I have a DK35 I purchased back 2005. Back then the DK series was bigger line of Kioti tractors. Seems like they had a renaming of their tractor lines since then. Anyway my DK35 has been a flawless performer for me and I ran it hard mowing steep fields of high grass, weeds and sometimes trees. Yikes! All the while pulling a 6' brush hog. If I could push it down the Kioti would cut it off. What a beast!
Thanks for the help.
   / Kioti K9 Parts #7
Generally if you take off the first Wix number you have a Napa number.
Should be a Napa 1381
My 2001 DK 35 also calls for the Napa 1381
   / Kioti K9 Parts #8
I've had the same luck with my DK 35 since 2001.
It's been an excellent tractor
   / Kioti K9 Parts
Vince,
They are telling me I need oil filter E5205-32091. Does that make sense to you?
Thanks
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
Unused Delta Crash...
PAIR OF SINGLE AXLE TRAILER FENDERS (A51247)
PAIR OF SINGLE...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
